I found an error in my episode guide, how to fix metadata?
I have recently added the office to my plex server and everything was working great till I started watching season four. I noticed that the metadata being pulled was not lining up with the actual episodes. I think the disparity is that imdb is correctly displays the info where the TVDB splits the episodes out which makes them not align:
How can I have it pull the imdb episode listing and refresh the metadata ?
Server Version#: Version 4.81.1
Player Version#: Version 1.26.0.5715
Plex uses episode ordering from The Movie Database or TheTVDB (aired/dvd/absolute).
You’ll need to align your episode naming/ordering with one of those choices.
Specific to Season 4, it looks like the IMDB order aligns with TheTVDB DVD order (season 4, dvd order).
You should check the rest of the seasons first, but you can tell Plex to use TheTVDB DVD order.
  1. Edit the Show, not season or episode (pic below).
  2. Advanced tab
  3. Change Episode Ordering to desired option (pic below).
  4. Save Changes.
Screenshot (1284)
That fixed it!!! Thank you!!
