I have a playback issue with a specific track in Plexamp
Server Version#: 4.149.0
Player Version#: 4.12.4
I have a playback issue with a specific track in Plexamp. The track gets to around 80% complete and then skips or quits. I would like to submit logs somewhere. I have tried changing the quality of the stream (opus, flac) and it makes no difference. This is the only (of thousands) track in my lib with this problem. Metaflac claims the stream is intact and the file plays fine in the web version of plex.
Probably a corrupt track, you can play and submit Plexamp logs, unless it’s converting on the server in which case Plex Media Server logs, but I’m virtually certain there will be some sort of corruption in the track.
It looks like you did a few seeks and then the track ended:
Aug 24, 2025 23:31:11.018 [0x70953000] INFO - BASS: Stream 500355 gave last byte at 193.5 sec (mixer time 24.4 sec).
The duration of that track appears to be 250462 (250 sec) that would be indicate a premature end. There’s no explicit error, but the only reason for that to happen is if there were bad data in the stream. You could try uploading the track for us to have a look at but really.
I deleted the caches and that solved the problem.
Hmm, that would imply that somehow your cache was corrupted, which is unlikely (not aware of any issues with it) but glad that resolved the issue!
