I have problems with PLEX set up
  1. Problems setting up live TV/DVR: Initial Live TV/DVR setup was easy and worked well. However, due to unrelated tech issues, I had to remove the server from my nvidia shield. Now that the server is set and running again (on my nvidia), I can’t set up live TV/DVR; plex has problems finding hdhomerun prime tuners. When I manually add the IP address, I get a message: “There is a problem adding the device”. Hdhomeun view works fine.
  2. When I try to stream some media files that worked before, I get a message “unable to play media”
I don’t know if these issues are related.
Please help!
Thanks a lot for you time
please provide logs
please see attached
I see in your log where PMS is searching but it says your tuner isn’t responding with the appropriate response so it thinks it is an incompatible device. Can you provide me the entire log set? There is a more details tuner log that I would like to see.
please see attached
Thanks!
No, that’s not what I wanted. Please use Plex Web, Settings \ Server \ Help \ Download logs.
Sorry, don’t know exactly what you need…
Please be a little more specific.
Sorry, I got it…
here you go…
Can you confirm what model tuner do you have?
HDHomeRun Prime1323BC3D
Can you enter this manually into a browser and let me know the results? Is that the correct IP for your tuner?
http://192.168.1.158/discover.json
That’s what comes up:
FriendlyName “HDHomeRun PRIME”
ModelNumber “HDHR3-CC”
FirmwareName “hdhomerun3_cablecard”
FirmwareVersion “20170930”
DeviceID “1323BC3D”
DeviceAuth “SexKfuZncKiYuJLuTpv3h8FE”
TunerCount 3
ConditionalAccess 1
BaseURL “http://192.168.1.158:80
LineupURL “http://192.168.1.158:80/lineup.json
Plex finally found the tuners and I was able to set live tv/DVR. Thanks!
Any idea why am I getting “unable to play media” message?
Thanks again
I wonder what happened. That response you provided is what pms is expecting, but for some reason it wasn’t working when pms asked. Double check your network connections. Maybe your Shield is connection to something that isn’t working properly.
For your new issue, I’ll need to see the log for that error.
My pc and shield are connected via ethernet. I didn’t make any changes with my network lately.
Which logs do you need?
Just a few ideas. A firmware update on your router? A firmware update on the Shield? Maybe you need a firmware update on your HDHR?
The Plex client app on the Shield. That’s the client you were using right?
  • I’ll definitely update the firmware
  • Do you need all logs?
Unfortunately my plex live TV is not working well, - distortions and error messages, stops playing. Also Hdhomerun view program doesn’t work as usual, a lots of distortions. As soon as I uninstalled plex live TV, distortions in hdhomerun viewer were gun.
So you got PMS to see your DVR again?
That is odd. We don’t interact with the HDHomeRun viewer program. You have the Prime, which has a built in transcoder. PMS does set how this works. I don’t know if this setting is within the Prime so the Viewer program ends up using the same setting. If you re-setup PMS DVR, maybe try playing with this setting. I’ve seen reports where the built-in transcoder doesn’t like certain TV signals. Turning it off would help if this is the case.
