I installed DSM7 and when i start Plex, i cannot see my Plex Media Server even if its running state
Hi Chuck
Okay. I will try this one. You have copy to me the link for the x13 and x14 series.
This link now is for the x18 series.
I will try and answer to you.
Thank you so much
I am sorry. I somehow thought the one compatible with x13 also.
(there are two choices there)
The first choice is “armv7hf” (hardware floating point)
The second choice is “armv7neon” (neon hardware extensions)
To alert you in advance,
Starting with PMS 1.28.2 the web browser will return a strange looking page.
It will be code 503. “Temporarily unavailable”.
This is PMS telling you the database is being updated so you don’t panic.
All you need do is watch the CPU.
It will go from 25% (during database upgrade) to the full use startup spike and then back to normal when everything is complete.
Okay. This update has finished now.
But now when i click to My Media there is this message which tells me that i need Media Server
So it seems that Plex have not access to my movies? Can that be?
If you want, you can connect via TeamViewer so we can chat together and you can maybe fînd what is still wrong?
Hi Chuck.
I am back from work. You can answer to me when you are ready to check whats wrong with this Plex Server.
I have tried everything. I have also tried to install the plex media server on my game PC and there it is working well. But its not a solution for me because i want to have it on my Synology.
Thank you
Nico
