I Really Would Like Trailers
I just want trailers to play before movies. I’m plex pass member… I’ve read thru forum posts. I’ve gone to my Linux server and made sure play 2 trailer’s is up. I’ve gone into the Web app and made sure the freebase press and movie database are set. I’ve gone into my Web app player and made sure settings have play 2 trailers. I’ve gone into my Android tablet and set 2 trailers… NONE of them work… no trailers ever play…
Anyone have any helpful suggestions?
Is your server signed in to plex.tv?
What did you set under Settings - Server - Extras ?
Is the following checkbox enabled in the preferences of your movie library (‘Advanced’ tab): ‘Enable Cinema Trailers’?
Is the realtime clock of both your server machine and your client set correctly?
@OttoKerner said:
Is your server signed in to plex.tv? YES
CINEMA TRAILERS FROM ALL MOVIES, INCLUDE CINEMA TRAILERS FROM MOVIES IN MY LIBRARY, INCLUDE CINEMA TRAILERS FROM UPCOMING BLURAY
Is the following checkbox enabled in the preferences of your movie library (‘Advanced’ tab): ‘Enable Cinema Trailers’? > ??? Checking
Is the realtime clock of both your server machine and your client set correctly? YES
HOLY MOLY !!! How can 1 little checkmark be such a pain in my bottom… it was the library part for the group movies… THANK YOU SO MUCH…
