You want to use Collections to “group” all of your Star Wars movies, once you’ve properly Split them back apart. You may need to Fix Match after you’ve split them because you literally told your server that all of those separate movie files were all just multiple copies of the same Star Wars film and it will continue to think that until you tell it otherwise.
