Hello All,
Is there any way to force Plex to match TV Show filenames that contain text such as -scene and -short in them.
I name all of my TV shows as follows:
ShowName/Season.xx/ShowName.SxxEyy-EpisodeName.mkv
For example: Chicago.Fire/Season.04/Chicago.Fire.S04E09-Short.and.Fat.mkv
In the above example, the episode is not matched and does not appear in the season. I believe this is due to the -Short in the filename. (I’ve come across others which contain -Scene as well)
When I find this issue, I simply rename the file to Chicago.Fire.S04E09-**’**Short.and.Fat.mkv which I am OK with, but was just wondering if I can avoid having to do this since I automate renaming, encrypting and uploading to my amazon cloud drive.
I have already disabled the Local Media Assets scraper as well as the “Find trailers and extras automatically” in TheTVDB Settings.
Thanks in advance
