I’m not able to add media library in my account
In order to complete the setup you need to open your Plex Media Server through its local IP.
If you’re on the same device… open http://127.0.0.1:32400/web in your browser. If you’re on a different machine inside your home network, use http://[PMS IP address]:32400/web instead. This will bring up a wizard/dialog where you can name your server and link it to your Plex account (as well as creating your first libraries).
Once you “claimed” your server (=linked it to your Plex account), you’ll also be able to access it from other Plex apps or via http://app.plex.tv/desktop.
https://support.plex.tv/articles/200288586-installation/
If you haven’t already claimed your server, you should also be able to manage it using the local interface (incl. adding new libraries)
