Importing iTunes Playlists - SHould be a Feature Within Plex
Hi
So I really am trying to use Plex as my single, all-encompassing Media Server
I am frustrated that the ability to import iTunes playlists (of which I have hundreds) no longer works
Unless I want to create them all manually again in Plex, it seems that I have to use the services of a 3rd Party organisation (Soundiiz) which still requires manual work to export each playlist from iTunes and then manually import each one into Soundiiz (unless I want to pay)
Surely Plex see the inability to have plex be able to do this simply and in one step as a drawback when trying to position your product as a serious media server (I know that it used to use the iTunes XML file capability to achieve this but it was disabled by Apple I believe. And whilst this is unfortunate for Plex, its life. Sometimes you gotta have important functionality in your own product)
Regads
A response from someone at Plex would be nice.
