Server Version#:last
I have a maybe easy question
I have one move Indian Jones the First Movie Fromm 1981.
I cando whatever the Movie will Not Shown up.
Do you have Andy idea WhatsApp i Clan do?
Could be a number of reasons… e.g. bad permissions or file naming/organization, possibly some unsupported file type (e.g. some disc image / iso).
Have you already filtered your library for „duplicates“? This should bring up items that contain multiple files… which can happen if Plex mismatched one of the files due to misleading file naming.
Plex Documentation → Your Media
→ Naming & Organizing Your Movie Files
→ Naming & Organizing Your TV Show Files
Make sure you have the movie named and organized per Plex requirements.
After renaming, Plex Dance the movie to remove any previously incorrect matching information.
This works on my system. The IMDB ID is optional, but tells Plex exactly which movie to match.
/movies <-- folder added to movie library
.../Indiana Jones and the Raiders of the Lost Ark (1981) {imdb-tt0082971}
....../Indiana Jones and the Raiders of the Lost Ark (1981) {imdb-tt0082971}.mkv
I have 4 movies and all 3 shown correct. Ich only his one makes trouble
IT also Shows hat IT foundcthe movie bit still Not listed… See screenshot
Sorry i had to do it on my mobile and it automatic correct it to german all the time Ort Mixed it up ![]()
All Other Movies are shown correct…….so Around 50. so no rights Problem or something like this
It appears the movie is added to your library and should be listed as „Jäger des verlorenen Schatzes“ (as per your screenshot). Depending on your library configuration the movie might be hidden/collapsed in an Indiana Jones collection. You should also be able to see it in the „Recently Added“ hub („Zuletzt hinzugefügt“).
If that’s not the case, you’ll need to provide some more information… the screenshot itself isn’t showing all that many information (aside of the activities popup).
On a more general note: permissions can be messed up for folders or individual files… so other files being properly seen doesn’t rule out any permission issues. That being said… given the file is being processed in your Plex Media Server, that doesn’t seem to be a problem here.
The first movie wasn’t named “Indiana Jones and the …” It was just “Raiders of the Lost Ark.” Could this be causing problems?
German title of „Raiders of the Lost Ark“ is „Jäger des verlorenen Schatzes“ (lit. „Hunter of the lost treasure“) or „Indiana Jones und der Jäger des verlorenen Schatzes“ (lit. „Indiana Jones and the hunter of the lost treasure“)
Still you’re right… it’s not just called „Indiana Jones“
IMDB (in US/English) now lists it as “Indiana Jones…” with “Raiders…” as an alternate title. Either should work fine, especially if the IMDB/TMDB ID is used.
The original title is “Raiders of the Lost Ark” (1981)
It was only after the Box Office smash status of “Indiana Jones” that the name was added ![]()
From my library:
===== /glock/media/uhd/Indiana Jones and the Kingdom of the Crystal Skull (2008)/Indiana Jones and the Kingdom of the Crystal Skull (2008).mkv (51575 MB) ======
===== /glock/media/uhd/Indiana Jones and the Last Crusade (1989)/Indiana Jones and the Last Crusade (1989).mkv (52423 MB) ======
===== /glock/media/uhd/Indiana Jones and the Temple of Doom (1984)/Indiana Jones and the Temple of Doom (1984).mkv (52812 MB) ======
===== /glock/media/uhd/Raiders of the Lost Ark (1981)/Raiders of the Lost Ark (1981).mkv (51407 MB) ======
[chuck@lizum ~.2000]$
Renamed to raiders of the lost ark but still the Same
Of Course the Server is german it Showdown up in german
But still Not Listen as you Clan See but it will be Detected as Bedford
tmdb-85
imdb-tt0082971
All of these give the correct match.
If this is an .mp4 file make sure you don’t have any embedded metadata in the properties giving you an incorrect match
Input the tmdb or imdb number into the file and plex dance
Raiders of the Lost Ark (1981) {tmdb-85}
Fix match should also work
AHHHAAAAAA now its listed…i changed the libery agent from plex movie to the movie database and directly after that he told me that the is a better version if i want to switch…so i did he rescanned everything annndddd taaaataataaaaaa
hmmmmmmm i can see it now in the media archive but if i search for it still no luck…arrgg
You searched for „Indiana“ but neither the German nor original (English) titles contain that term…
you are totaly right …i just saw it on my own…the picture sais indiana jones but the movie call jäger der verlorenen schatzes…nooo indiana in :)))
■■■■…totaly my fault…sometime it could be easy
As a side note… collections are your friends when it comes to grouping such movie series/franchises (and they give you another opportunity to find an object by a name containing the term „Indiana“)
