Server Version#: Version 4.85.1
Player Version#: any version
Being quite desperate over here… I have Plex in place now since about 5 years without any major troubles. Now since more and more movies are not being recognized by the Plex server:
The movies are not shown on Tizen and on the web gui
I am running Plex server on Synology NAS
I only download mkv files
The file names do not contain any of the words being filtered out
The file structure is the same since years: Movies/Movies, Movies/Series (two libraries)
I have tried the following already:
Renamed the name of the movie files
rescanned library / rescanned meta data
recreated the libraries
moved the files to different locations within a new temp. library
uninstalled and re-installed Plex server (completely uninstalled with removal of all settings)
I’ve read through a number of articles, it has nothing to do with the path of the files (since most of the movies are being recognized), no file name violation, no codec issue (it’s 1080p x264, x265). The files have different sizes (between 2Gb and ~10Gb.
When I play these files on my PC with VLC all is fine.
Mind sharing a specific example?
Have you already filtered your library for duplicates to see if Plex maybe misplaced the items and matched the files to another movie in your library?
Hi, for some movies I had to add the imdb id for Plex to correctly recognize it. E.g. add {imdb-tt2382320} for a bond movie directly after the movie name. Cheers, Alex
@PunkleJones
I have re-installed Plex from scratch, the same movies are still missing tha have been missing before
@tom80H
Filtering on doublicates only shows 3 movies with real doublicates
Example of a path: \diskstation\Filme\Filme\Massive.Talent.2022.German.AC3MD.1080p.BluRay.x264-ODiN\Massive.Talent.2022.German.AC3MD.1080p.BluRay.x264-ODiN.mkv
@granjan7
No filename violations according to the Plex documentation
@relex_quickline_ch
I’ve already tried to add the imdb id in the file name. Nothing works
Edit:
This is a naming example according to the documentation / official naming schema:
diskstation
Filme
Filme <- folder linked to your library
Massive Talent (2022)
Massive Talent (2022).mkv
If you need to keep the technical stuff, put it in square brackets so it doesn’t interfere with your Plex Media Server, e.g. Massive Talent (2022) [German.AC3MD.1080p.BluRay.x264-ODiN].MKV
That’s the same problem i’ve been having. Plex refusing to see newly added movies, but not all consistently. Some movies gerts added straight away. (im also NOT “updating” my libraries. The new ones is garbage and removes movies already added)
Not gotten any solution for it expect “plex dancing” again and again until maybe Plex gets tired of it and add the files out of spite.
I dont see a movie called “Massive Talent” from 2022. There is " The Unbearable Weight of Massive Talent" from 2022, so possibly correctly naming the file would help plex.
You need to use the English movie name, not a localized version of it. My standard suggestion is:
If you want to save yourself a lot of time I would recommend using Download - tinyMediaManager and use ${title} (${year}) {imdb-${imdb}} as the new name format.
That’s not necessary. Plex is perfectly fine with localized titles in your files. The only use case where you must use English language folder names is for the Season folders in a tv-show.
Renaming the files does not have any impact on the fact that these movies are not being shown. Also, when I store self recorded videos in the same folder, they get shown - obviously without any meta data. Why is this not happening with some of the downloaded movies?
If you are using the Plex Movie scanner and agent, add the IMDB or TMDB ID to the folder and file name. /Massive Talent (2022) {imdb-tt11291274}/Massive Talent (2022) {imdb-tt11291274} [other stuff].mkv
With 5 years under your belt, I’m guessing you know how to name things and generally run the system, but with age sometimes you get a Dad bod, and in terms of linux, you run out of inodes.
