This thread stsrted by helping someone with the error “you do not have access to this server” I have attempted dozens of walk throughs to set up plex on my synology and nothing works.
Synology ds920+ purchased two days ago. Upgraded to dsm 7. Added files. Installed plex as this was the order of the video I was watching for plex setup. And I get that error message.
I have uninstalled and reinstalled several times now. Granted permission. Used claim token. Nothing works. Bought this nas as it was reviewed by multiple people on YouTube to be the best home nas for plex.
I seem to have the same problem, getting a “Not authorized” error when starting the “Plex Media Server” tile on Synology DSM 7, so I can’t run the wizard.
In the log I see the error message below. Some people claim they solved this by updating to the latest version but I am already on that.
Any ideas what’s going on?
DEBUG - NetworkServiceBrowser: Parsing SSDP schema for http://192.168.178.31:9080
DEBUG - HTTP requesting GET http://192.168.178.31:9080
DEBUG - HTTP/1.1 (0.0s) 200 response from GET http://192.168.178.31:9080 (reused)
ERROR - XML: Entity: line 1:
ERROR - XML: parser
ERROR - XML: error :
ERROR - XML: Start tag expected, ‘<’ not found
ERROR - XML: status=ok
ERROR - XML: ^
ERROR - Error parsing content.
ERROR - Error parsing XML: Error parsing file.
ERROR - SSDP: Error parsing device schema for http://192.168.178.31:9080
BTW: In the browser log I see a 401 for the following URL (I masked some fields):
Previously I was opening the URL from the app inside DSM, which then opens my browser. Now I have used the link you provided above directly and this works, on the second attempt.
On the first attempt, I was asked to confirm the user and then the browser was busy without any (visible) progress. In the dev tools I saw it looping over the same (?) set of URLs, some 192.168* and then 127.0.0.1., again and again, with errors.
After some time I closed the browser and tried again, and this time the setup UI immediately showed up. Not sure why, but so far so good.
