iOS subtitle submenu slider
Server Version#: latest
Player Version#: latest
So since the new iOS glass nonsense, this new menu type has been driving me nuts. It crashes the app nonstop, and obscures its menu under the app switcher for the iPad.
Basically, when trying to change subtitles or audio, it opens a discrete menu part way at the bottom of the screen. Then you must very carefully and slowly swipe it up to select other options… then 5/10 times it crashes the app. I spent 3 hours on the phone with Apple, who told me it’s all your fault, per usual and they have no way to even look up what this menu system is called.
Does anyone know if this is a choice by plex? Or if this is a forced system update from Apple? Is there any way to change it back? It’s really destroying my plex experience.
