Just upgraded to a new iPhone 16. Reloaded the PLEX App.
When I log on, lands on a screen “Pick Your Favorite Libraries”.
There is a continue button at the bottom, but either grayed out or not functioning for some reason.
Anyone have an idea what is going on and can offer a solution?
I have the same issue since yesterday. What is going on ? The app was working perfectly OK till yesterday - I used it on a daily basis on my iPhone ! I have the newest 2025.10.2 version. Please fix it as everything was working on 8.45 !!! I still have 8.45 on my iPad and it WORKS - contrary to 2025.10.2 WHICH DOES NOT !
If your sole library is of the type “Music” or “Photos”, you will need to use either Plexamp or Plex Photo respectively.
The new iOS app can only handle Video-type libraries.
Thank you Otto! I already figured this our from other forum topics. There is a functionality in PLEX which is not available in PlexAmp. The 10/30 seconds backwards/forwards playback was very useful when playing Audiobooks. Also PLEX KEEPS TRACK of PLAYBACK PROGRESS PER TITLE.
PlexAmp misses all these functionalities !
Are they going to be added in the future ?
No, it doesn’t miss them.
Enable “long form controls” in Plexamp’s Settings - Experience - Player.
Do also enable “Music Quick Skip” and “Music Playback Speed” if you like.
Use the “Quick Skip Times” preference to adjust the skip forward and skip backward times to your liking.
Then enable “store track progress” in the properties of the audio book library.
Hi and thanks for the help ! Indeed - I was able to follow up all your recommendations and every issue I had is resolved.
