Is it possible to delete and start again? I think I've messed it up
Hi, I have managed to install Plex on my NAS drive, but I didn’t create libraries for my TV shows and now they are all dumped in the Films library.
I have been trying to fix it, but not having any luck. Wondering if it’s easier to start afresh?
My files on my NAS drive are set up correctly, following the naming rules, but the TV shows are listed in the films library. I have tried creating a new library for TV shows, but can’t seem to make the files move into it.
Any advice or suggestions welcome. Please forgive me if I use incorrect terminology. It’s a steep learning curve for me, but I’m getting there.
UPDATE: I have just managed to get some episodes to show in the TV library. Yay! But there is still some showing in the films library. How do I remove them please?
By putting movies and series in totally separate folders.
Then point the respective Plex libraries to the correct folders only.
https://support.plex.tv/articles/200289266-editing-libraries/
P.S. You might wanna bookmark: Synology FAQ - Questions, Answers, and a few How-To's
Thank you.
Will give it another try. :slight_smile:
