I would like to create a playlist of matched media, specifically video files where metadata has been added by an agent. I want to be able to check the matches to make sure that they are correct. (I’ve found that in one of my libraries, they often are wildly off.) It seems like there is a way to search for unmatched media, but not for matched media. Why is this? Is there any way to create a search or smart playlist of matched media?
For movies, level 3 as a minimum, and sort on the field named Metadb link
For episodes, level 4 is req.
Thank you so very much. It took me about ½ hour to decode what you were talking about, but now that I have I feel like I’ve leveled up!
Sorry if I was a tad unclear here, and not native English speaking, so if you mind, please help me helping others, and tell how I should have phrased my post.
And cool you got it
This is a useful solution but awkward in execution. (Need for manual install, need to give user name and password to a third-party plugin, need to launch via one of two Plugins menus under Settings, need to open the data file in a separate app and copy-paste data back and forth between it an Plex…)
What really needs to happen is for all of this functionality to be incorporated into Plex proper, such as with Filters or Smart Playlists, so a person can build powerful DB queries graphically.
