Issue connecting to own server
I had to do a recent update and I switched from Wireless to Wired connection. I was unable to access or update my library. I uninstalled and tried again and now there is no library option. When I tap YOUR MEDIA it takes me to the page and tells me to download the Plex Media Server . Any ideas?
Can you access the server using the web app on http://[PMS IP address]:32400/web ?
I’m not sure how deep you went with uninstalling your old server… if you deleted the server data directory, not just the executables, those libraries could be gone for good.
Edit: I’ve moved your post to its own thread as it wasn’t really related to the other thread where you had originally posted it.
I deleted everything it seems but my data was is all there on the harddrive but I dont even have the option to add anything it tells me to download the server i have and i even tried older version
Do I need to have A Premium Pro account now to have move own media ?
No, you don’t.
Did you test accessing your server from a browser using its local address (http://127.0.0.1:32400/web if you’re on the same machine)?
that is the address that opened when I pressed the icon on the bottom
