Issue in Synology DS115J upgrade from 1.13.4.5271 to 1.15.1.791
Server Version#:
Hello,
I have tried to upgrade my Plex server for my Synology DS115J.
I was using 1.13.4.5271-200287a06 and upgrading to last 1.15.1.791-8bec0f76c.
I have downloaded the PlexMediaServer-1.15.1.791-8bec0f76c-armv7hf.spk.
Now my server is launched but no more accessible.
I have checked the logs and getting only this :
Mar 19, 2019 20:31:02.127 [0x454f7400] WARN - Warning: ex: boost::filesystem::last_write_time: No such file or directory: “/volume1/@appstore/Plex Media Server/Resources/Plug-ins-200287a06”, couldn’t check file: “/volume1/@appstore/Plex Media Server/Resources/Plug-ins-200287a06”
It seems that 1.13.4 is the last supported official version on Synology website : https://www.synology.com/fr-fr/dsm/packages/Plex_Media_Server
Do you have any clue with this ?
I’m trying to rollback to my previous version, I hope I will succeed and wont loose any of my settings and library.
Cheers,
Hi again,
Everything is fine finally.
I have stopped my server, reboot, reinstall then launch.
So it seems it was a installation issue (maybe a launched process not properly killed during previous install).
Regards,
I’m having the very same issue. I’ll try to reboot right now.
