Issue playing "all" on PS4
My Setup
3 Core CPU VM
4GB RAM
Ubuntu 14.04.3
Plex Server v 0.9.15.2
I am having some issues regarding stability on PS4. It is crashing and failing to load some files. I am not reporting on this as I have not yet fully studied how/when files are determined to be transcoded etc. but I am not having these issues on my Android app or in the browser.
One issue I was able to pinpoint was while trying to stream a season of a show. I hit the play button such that episodes will play consecutively, and it will play a complete episode without issue but then fail to load the next. I am attaching the output of the media server log, and the XML info for the file.
It is worth noting that I can close the app, open it back up and play it. If I try fast forwarding, or skip ahead in any way it would crash… so there’s that too… I’m just a little confused because the media file isn’t particularly large and/or high-def.
Anyway… any help is greatly appreciated!
Have similar issue.
Plex on PS4 and android will only play .mvk files.
Everything works from PC.
No changes have been made, everything worked before latest Plex Server update.
