Issue with marking viewed files
HI
  • Your ATV model (2 or 3) and firmware version (found under the ATV settings > general > about > Apple TV software):
    • ATV 2, FW 5.3
  • The DNS server set on the ATV (found under the ATV settings > general > network > DNS):
    • 192.168.0.7
  • The device and operating system (including version number) that PlexConnect is installed on:
    • Mac Mini, Mac OS X 10.8.5
  • The local IP address of the device that PlexConnect is installed on:
    • 192.168.0.7
  • The device and operating system (including version number) that the Plex media server (PMS) is installed on:
  • The Plex media server (PMS) version number you are running (do not put 'latest'):
    • 0.9.8.10.215-020456b
  • The local IP address of the device that the Plex media server (PMS) is installed on:
    • 192.168.0.7
  • The PlexConnect version number. If using Github source then a time and date of download (look at the creation date of the folder) and if you are using any testing branch e.g. the Elan/PlexInc one.
    • PlexConnect-master, downloaded  November 29, 2013
  • Content of the Setting.cfg
[PlexConnect]
port_pms = 32400
port_webserver = 80
ip_plexconnect = 0.0.0.0
certfile = ./assets/certificates/trailers.pem
ip_dnsmaster = 8.8.8.8
loglevel = Normal
enable_dnsserver = True
logpath = .
ip_pms = 192.168.178.10
enable_plexgdm = True
hosttointercept = trailers.apple.com
port_ssl = 443
enable_webserver_ssl = True
prevent_atv_update = True
port_dnsserver = 53
enable_plexconnect_autodetect = True
  • Detail on the media file if it is an issue related to playing a media file
    • not related to specific media file
  • A detailed description of the issue
    • After watching a TV show, when show is viewed, the "viewed" information is not updated, either on the aTV nor in PMS.
    • Plex seems to not remember where a show is stopped when restarting to play (always restarting from start)
    • was working perfecly with version from September 6, 2013
  • 'PlexConnect.log'
    • see attached zip (was not able to post it through pastebin, too big)
I found this when updating sometimes, try rebooting the ATV and then watching a test episode.
Hi f00b4r
I'll check this out this evening
Edit : just tested, works far better after aTV reboot
Bruno
Finally, this does not work that good…
Two days ago, after rebooting aTV it was ok, but yesterday evening, the problem re-appeared :
  • impossible to stop a video and restart from the same point -> systematically starting from start
  • impossible to have the “viewed” information updated after viewing a show
    New one :
  • impossible to choose a subtitle on one show (will chech this out this evening)
    Finally, I’ll go back to my previous version.
    Bruno
