Server Version#: 1.29.2.6364
Player Version#: All
Hi…
I had Plex running on a win 7 old PC for years, no major issues.
Box had the motherboard die on me, so had to rebuild onto another PC, similar spec’s etc (Intel Core 4, 8G ram, etc etc).
Once I had done a fresh Win 7 install and all the updates (that was fun!), I installed plex server the same version that the old one was running (current non-beta)
I then copied the plex data from the old PC to the new one, then started plex.
had to reconfirm library locations (it already had them, but made me go through the usual instal install screens), then all looked OK.
At this point, all looked OK, all my library appeared to be in order, only hiccup was Plex recognised this as a different server (even though it’s named the same, on the same IP etc etc), so had to reset customisations in the clients to see the ‘new’ server’s libraries.
All then seemed OK, could play stuff on local TV’s etc as before, no difference.
then the fun bit, all the friends shares I had set were gone - I assume it’s because it’s a different server as plex see’s it, so re-set all of them - that all worked OK.
Now the problem…
for some reason, bandwidth to the internet is being limited to ~3Mb no matter what, as in if I am trying to stream to my phone when it’s NOT on Wifi.
same deal with Roku sticks etc that are remote.
Checked the ‘Remote Access’ settings, and all is as before, - in my case that’s manual port selected, and manual port forwarding in the router.
The plex server reports all is OK, but the bandwidth is still being limited by something, I have set the internet upload speed to 100M (just to ensure that’s not it), and the ‘Limit remote streaming’ to original (no limit).
Obviously, both local and remote use the same network interface (usual gig Ethernet), and locally the Roku’s can run over 250Mbit/s no problem.
I then attached the router, cleared out all the entries for this PC and re-entered them new (just in case it had some hangover from the old box), made zero difference.
So, then I thought is might be a problem with the way Plex installed, so I checked for updates and installed the latest Beta ( 1.29.2.6364), zero change.
It’s still limiting remote connexions to ~3Mb - each - it will support more than 1, but each one seem to be limited to ~3Mb?
This may not be a Plex issue, but I am struggling to think what else it could be?
Ideals anybody?
Thanks in advance.
Simon
PS. been going through the loggs on windows and found a stream of entries in network profile:
event ID: 4001 and 4002
doing a quick search implies a problem with a registry setting or the like (although most are talking about WLan stuff).
I have checked and change the NIC driver too just to cover that off…
