I’ve looked in the forum and tried to find an answer but I couldn’t really.
Since earlier today my Remote Access is not working anymore. I noticed that the PUBLIC IP within Plex is different to the one on whatismyipaddress.com and on my router. The router and whatismyipaddress.com both show the same (as does IPCONFIG within the CMD).
Having the same problem here. It’s been driving me crazy for the past hour.
I downloaded your logs and my server is giving me the same public IP as you - 64.188.30.130
I run two servers on my network so I forward port 32400 & 32401 - both servers report the same incorrect public IP - 64.188.30.130. One server is running on a Synology, the other a Windows desktop.
Hopefully this can be fixed because I’m guessing we’re not the only ones affected!
I’m in Melbourne, Australia using Aussie Broadband as my ISP. Definitely not behind a double NAT. Aussie do employ CGNAT for their customers but I’ve opted out and have been using Plex remote access daily for over a year and I’ve had the same public IP for months…
My actual public IP is 202.142.XXX.XXX but Plex thinks it is 64.188.30.130 (same as sneakybastard from his logs). At first I thought someone had compromised my account but I’ve reset my password and it’s still happening…
Never mind, I’ve got mine working again. The problem was caused by my DNS provider - Getflix SmartDNS.
Doing an nslookup on plex.tv returned 64.188.30.172 when using Getflix’s Sydney and Melbourne DNS servers. Changing my DNS server to 1.1.1.1 gave the correct result for plex.tv - 99.80.231.223 / 99.80.242.242 / 99.81.213.165
Changing my DNS server to 1.1.1.1 and restarting remote access on Plex fixed the problem.
No worries. I’m thinking maybe Getflix are trying to make region switching available for Plex’s new Movies and TV service so that their customers aren’t geoblocked for some titles.
9 hours later and the Getflix DNS is now resolving plex.tv properly so I’d say you should be able to restart your remote access now and have it working again…
I was having the same problem (I’m in NZ). Only started happening in the last couple of days. I thought it may have been down to the new version of Plex Server (1.18.3.2129) on my Synology.
I removed the Getflix DNS settings on the router and back to using the ISP one and all worked again.
So, following on from @grantfisher solution (thanks!), I changed the DNS server settings on my Synology Control Panel/Network to 1.1.1.1 & 1.0.0.1, and re-enabled the Getflix DNS on my router. Seems to work so far!
