Issues with TV Show: Detail (TVDB-415087)
I am just worried the old agent will be discontinued at some point, and it also can’t get Season Titles. It seems like a really simple fix to have Plex Series agent allow you to overwrite the source
Bump?
Any updates here?
It doesn’t look like TheTVDB has made any movement on this. I’ll see if I can reply to my original ticket.
All these separate shows still exist:
Cool, thanks. They’re all just stubs linking people to the “new” (correct) show, though. If we need to get them removed entirely, that’s not a problem.
Should all be dealt with now :slight_smile:
Excellent thanks!
I’ve reported the bad TMDB show data now, hopefully I can get them to just fix the title for now which should resolve the main issue as it’s also linked via id to the TVDB and IMDB ids (which is a locked field).
