iTunes Library on a Mac via Plex Media Server
You can only delete individual playlists. Mouse over the playlist to see the … menu for that playlist. There will be a delete option there. If you want to remove all playlists to start over, select one, then shift select the last one, you’ll get a menu at the top, from there select delete.
OK - thanks. You’re being super-helpful.
(There’s 51!)
