Je ne vois pas un de mes repertoires de serie
Bonjour , J’ai ajouté quelques images du répertoire en question ainsi que des images des parametres de ma biblio.Pourtant la syntaxe est bonne.
Pourquoi ça n’apparait pas ?
I disagree.
Most important: Look at the file names in your last screen shot.
You are using S01EP02, whereas the official guidelines call for S01E01.
Bonjour Otto, j’ai changer la syntaxe des fichiers en enlevant le p, après avoir réinitialiser ma bibliotheque il ne les reconnait pas
Your naming is again wrong, its 2s01e01
If this is season 2 of the show, then it should start with S02
Please follow the link I gave you above.
Dear Otto,
I add two images, one for season one and the other is season 2.
I hope this time I am right
Hey Otto, I hope you have a way to zoom in my picture so you read it. I can zoom before I send you if its what you want I can do it
Looking good so far.
Though think of adding a (year) to the folder name of a show, if there are several shows by that title.
Otto, my syntaxe is good now I didnt see in my biblio
  1. verify that the library is of the type “TV shows”
  2. verify that the file are not already appearing under a different show title, like an alternate, or international title
  3. perform the Plex Dance
Hello Otto,
Problem solved I delete all the biblio and I reinstall all biblio , and my rep lac noir appear.
Tks for your support
