Languages changed after update blu ray discs
Hello
Some of my blu rays now play the wrong langauge. For example the film aliens clearly say English DTS MA and english DTS 5.1 yet when I play them the ifrst is directors commentary and the second is spanish.
When I select spanish it plays the german track - the german track plays english DTS
This was fine until I installed the update earlier this week.
Any advice would be great thanks
Jim
Which Plex client types are you using? If you use several different, have you compared their behavior?
Hi there
Yes I have a synology NAS and I have checked the plex app for langues on my PS4, my laptop and my mobile phone and my Nvidia shield.
All of the languages come up as what they say. This problm is only on my LG tv plex app.
I am thinking of unistalling the LG app and re installing it on the tv.
thanks
Thanks for confirming that this issue is restricted to the Smart TV app!
Could you please copy the ~20 lines from the Plex XML info of an affected video?
how do I get that info please
thanks Otto
Please click on the orange link.
the film in question is Aliens blu ray ripped via make mkv to a mkv file
the film is in h264 and the sound is DTS master audio for the english track ( which on the LG tv is directors commentary)
thanks
  • /volume1/Films/Aliens/Aliens_t09.mkv
Media
  • Duration 2:34:27
  • Bitrate 34452 kbps
  • Width 1920
  • Height 1080
  • Aspect Ratio 1.78
  • Video Resolution 1080p
  • Container MKV
  • Video Frame Rate 24p
  • Audio Profile ma
  • Video Profile high
Part
  • Duration 2:34:27
  • File Aliens_t09.mkv
  • Size 37.18 GB
  • Audio Profile ma
  • Container MKV
  • Codec H264
  • Bitrate 26615 kbps
  • Language English
  • Language Tag en
  • Bit Depth 8
  • Chroma Location left
  • Chroma Subsampling 4:2:0
  • Coded Height 1088
  • Coded Width 1920
  • Color Primaries bt709
  • Color Range tv
  • Color Space bt709
Sorry, this only tells me about the video stream.
I am intrerested in the audio streams. Their exact order and technical data. Which is what can be found in the Plex media info XML.
sorry didnt copy enough
  • Codec DCA
  • Channels 6
  • Bitrate 3981 kbps
  • Language English
  • Language Tag en
  • Audio Channel Layout 5.1(side)
  • Bit Depth 24
  • Profile ma
  • Sampling Rate 48000 Hz
  • Title Surround 5.1
  • Display Title English (DTS-HD MA 5.1)
  • Extended Display Title Surround 5.1 (English DTS-HD MA)
  • Codec DCA
  • Channels 6
  • Bitrate 1509 kbps
  • Language English
  • Language Tag en
  • Bit Depth 24
  • Profile dts
  • Display Title English (DTS 5.1)
  • Extended Display Title Surround 5.1 (English DTS)
  • Codec AC3
  • Channels 2
  • Bitrate 224 kbps
  • Language English
  • Language Tag en
  • Audio Channel Layout stereo
  • Title Stereo
  • Display Title English (AC3 Stereo)
  • Extended Display Title Stereo (English AC3)
  • Codec DCA
  • Channels 6
  • Bitrate 768 kbps
  • Language German
  • Language Tag de
  • Bit Depth 24
  • Profile dts
  • Display Title German (DTS 5.1)
  • Extended Display Title Surround 5.1 (German DTS)
  • Codec AC3
  • Channels 6
  • Bitrate 448 kbps
  • Language Spanish
  • Language Tag es
  • Display Title Spanish (AC3 5.1)
  • Extended Display Title Surround 5.1 (Spanish AC3)
  • Codec AC3
  • Channels 2
  • Bitrate 224 kbps
  • Language English
  • Language Tag en
  • Title Stereo
  • Codec PGS
  • Bitrate 51 kbps
  • Language English
  • Language Tag en
  • Display Title English (PGS)
  • Extended Display Title English (PGS)
  • Codec PGS
  • Bitrate 21 kbps
  • Language Portuguese
  • Language Tag pt
  • Display Title Portuguese (PGS)
  • Extended Display Title Portuguese (PGS)
  • Codec PGS
  • Bitrate 3 kbps
  • Language Tag pt
  • Codec PGS
  • Bitrate 19 kbps
  • Language Danish
  • Language Tag da
  • Display Title Danish (PGS)
  • Extended Display Title Danish (PGS)
  • Codec PGS
  • Bitrate 22 kbps
  • Language Finnish
  • Language Tag fi
  • Display Title Finnish (PGS)
  • Extended Display Title Finnish (PGS)
  • Codec PGS
  • Bitrate 22 kbps
  • Language French
  • Language Tag fr
  • Display Title French (PGS)
  • Extended Display Title French (PGS)
  • Codec PGS
  • Language French
  • Language Tag fr
  • Codec PGS
  • Bitrate 23 kbps
  • Language German
  • Language Tag de
  • Display Title German (PGS)
  • Extended Display Title German (PGS)
  • Codec PGS
  • Language German
  • Language Tag de
  • Codec PGS
  • Bitrate 40 kbps
  • Language Spanish
  • Language Tag es
  • Display Title Spanish (PGS)
  • Extended Display Title Spanish (PGS)
  • Codec PGS
  • Bitrate 6 kbps
  • Language Spanish
  • Language Tag es
  • Codec PGS
  • Bitrate 19 kbps
  • Language Dutch
  • Language Tag nl
  • Display Title Dutch (PGS)
  • Extended Display Title Dutch (PGS)
  • Codec PGS
  • Bitrate 22 kbps
  • Language Norwegian
  • Language Tag no
  • Display Title Norwegian (PGS)
  • Extended Display Title Norwegian (PGS)
  • Codec PGS
  • Bitrate 17 kbps
  • Language Swedish
  • Language Tag sv
  • Display Title Swedish (PGS)
  • Extended Display Title Swedish (PGS)
  • Codec PGS
  • Bitrate 63 kbps
  • Language English
  • Language Tag en
  • Codec PGS
  • Bitrate 51 kbps
  • Language Danish
  • Language Tag da
  • Codec PGS
  • Bitrate 53 kbps
  • Language Finnish
  • Language Tag fi
  • Codec PGS
  • Bitrate 52 kbps
  • Language French
  • Language Tag fr
  • Codec PGS
  • Bitrate 51 kbps
  • Language German
  • Language Tag de
  • Codec PGS
  • Bitrate 51 kbps
  • Language Dutch
  • Language Tag nl
  • Codec PGS
  • Bitrate 46 kbps
  • Language Tag no
  • Codec PGS
  • Bitrate 49 kbps
  • Language Swedish
  • Language Tag sv
Could you make another attempt of copying the XML source code?
<MediaContainer size="1" allowSync="1" identifier="com.plexapp.plugins.library" librarySectionID="4" librarySectionTitle="Movies" librarySectionUUID="9012b14f-5f86-484d-8150-7ebed7cb71d7" mediaTagPrefix="/system/bundle/media/flags/" mediaTagVersion="1628741429">
<Video ratingKey="3888" key="/library/metadata/3888" guid="com.plexapp.agents.imdb://tt0090605?lang=en" studio="20th Century Fox" type="movie" title="Aliens" librarySectionTitle="Movies" librarySectionID="4" librarySectionKey="/library/sections/4" contentRating="R" summary="When Ripley's lifepod is found by a salvage crew over 50 years later, she finds that terra-formers are on the very planet they found the alien species. When the company sends a family of colonists out to investigate her story—all contact is lost with the planet and colonists. They enlist Ripley and the colonial marines to return and search for answers." rating="9.7" audienceRating="9.4" userRating="10.0" viewOffset="3066658" viewCount="1" skipCount="2" lastViewedAt="1628893986" lastRatedAt="1628946038" year="1986" tagline="This time it's war." thumb="/library/metadata/3888/thumb/1628889682" art="/library/metadata/3888/art/1628889682" duration="9267008" originallyAvailableAt="1986-07-18" addedAt="1535308707" updatedAt="1628889682" audienceRatingImage="rottentomatoes://image.rating.upright" chapterSource="mixed" hasPremiumPrimaryExtra="1" ratingImage="rottentomatoes://image.rating.ripe">
<Media id="5695" duration="9267008" bitrate="34452" width="1920" height="1080" aspectRatio="1.78" audioChannels="6" audioCodec="dca-ma" videoCodec="h264" videoResolution="1080" container="mkv" videoFrameRate="24p" audioProfile="ma" videoProfile="high">
<Part accessible="1" exists="1" id="6080" key="/library/parts/6080/1556196615/file.mkv" duration="9267008" file="/volume1/Films/Aliens/Aliens_t09.mkv" size="39917255193" audioProfile="ma" container="mkv" deepAnalysisVersion="5" requiredBandwidths="2147483647,2147483647,2147483647,2147483647,2147483647,2147483647,2147483647,2147483647" videoProfile="high">
<Stream id="31544" streamType="1" codec="h264" index="0" bitrate="26615" language="English" languageTag="en" languageCode="eng" bitDepth="8" chromaLocation="left" chromaSubsampling="4:2:0" codedHeight="1088" codedWidth="1920" colorPrimaries="bt709" colorRange="tv" colorSpace="bt709" colorTrc="bt709" frameRate="23.976" hasScalingMatrix="0" height="1080" level="41" profile="high" refFrames="4" requiredBandwidths="35311,34292,33453,32524,31644,30766,29056,29056" scanType="progressive" width="1920" displayTitle="1080p (H.264)" extendedDisplayTitle="1080p (H.264)"> </Stream>
<Stream id="31545" streamType="2" selected="1" default="1" codec="dca" index="1" channels="6" bitrate="3981" language="English" languageTag="en" languageCode="eng" audioChannelLayout="5.1(side)" bitDepth="24" profile="ma" requiredBandwidths="2147483647,2147483647,2147483647,2147483647,2147483647,2147483647,2147483647,2147483647" samplingRate="48000" title="Surround 5.1" displayTitle="English (DTS-HD MA 5.1)" extendedDisplayTitle="Surround 5.1 (English DTS-HD MA)"> </Stream>
<Stream id="31546" streamType="2" codec="dca" index="2" channels="6" bitrate="1509" language="English" languageTag="en" languageCode="eng" audioChannelLayout="5.1(side)" bitDepth="24" profile="dts" requiredBandwidths="2147483647,2147483647,2147483647,2147483647,2147483647,2147483647,285389,285389" samplingRate="48000" title="Surround 5.1" displayTitle="English (DTS 5.1)" extendedDisplayTitle="Surround 5.1 (English DTS)"> </Stream>
<Stream id="31547" streamType="2" codec="ac3" index="3" channels="2" bitrate="224" language="English" languageTag="en" languageCode="eng" audioChannelLayout="stereo" requiredBandwidths="224,224,224,224,224,224,224,224" samplingRate="48000" title="Stereo" displayTitle="English (AC3 Stereo)" extendedDisplayTitle="Stereo (English AC3)"> </Stream>
<Stream id="31548" streamType="2" codec="dca" index="4" channels="6" bitrate="768" language="German" languageTag="de" languageCode="deu" audioChannelLayout="5.1(side)" bitDepth="24" profile="dts" requiredBandwidths="2147483647,2147483647,2147483647,2147483647,2147483647,2147483647,145248,145248" samplingRate="48000" title="Surround 5.1" displayTitle="German (DTS 5.1)" extendedDisplayTitle="Surround 5.1 (German DTS)"> </Stream>
<Stream id="31549" streamType="2" codec="ac3" index="5" channels="6" bitrate="448" language="Spanish" languageTag="es" languageCode="spa" audioChannelLayout="5.1(side)" requiredBandwidths="448,448,448,448,448,448,448,448" samplingRate="48000" title="Surround 5.1" displayTitle="Spanish (AC3 5.1)" extendedDisplayTitle="Surround 5.1 (Spanish AC3)"> </Stream>
<Stream id="84852" streamType="2" codec="ac3" index="6" channels="2" bitrate="224" language="English" languageTag="en" languageCode="eng" audioChannelLayout="stereo" requiredBandwidths="224,224,224,224,224,224,224,224" samplingRate="48000" title="Stereo" displayTitle="English (AC3 Stereo)" extendedDisplayTitle="Stereo (English AC3)"> </Stream>
<Stream id="31551" streamType="3" codec="pgs" index="7" bitrate="51" language="English" languageTag="en" languageCode="eng" requiredBandwidths="70,70,70,70,70,70,70,70" displayTitle="English (PGS)" extendedDisplayTitle="English (PGS)"> </Stream>
<Stream id="31552" streamType="3" codec="pgs" index="8" bitrate="21" language="Portuguese" languageTag="pt" languageCode="por" requiredBandwidths="28,28,28,28,28,28,28,28" displayTitle="Portuguese (PGS)" extendedDisplayTitle="Portuguese (PGS)"> </Stream>
<Stream id="31553" streamType="3" codec="pgs" index="9" bitrate="3" language="Portuguese" languageTag="pt" languageCode="por" requiredBandwidths="26,26,26,26,26,26,26,26" displayTitle="Portuguese (PGS)" extendedDisplayTitle="Portuguese (PGS)"> </Stream>
<Stream id="31554" streamType="3" codec="pgs" index="10" bitrate="19" language="Danish" languageTag="da" languageCode="dan" requiredBandwidths="28,28,28,28,28,28,28,28" displayTitle="Danish (PGS)" extendedDisplayTitle="Danish (PGS)"> </Stream>
<Stream id="31555" streamType="3" codec="pgs" index="11" bitrate="22" language="Finnish" languageTag="fi" languageCode="fin" requiredBandwidths="29,29,29,29,29,29,29,29" displayTitle="Finnish (PGS)" extendedDisplayTitle="Finnish (PGS)"> </Stream>
<Stream id="31556" streamType="3" codec="pgs" index="12" bitrate="22" language="French" languageTag="fr" languageCode="fra" requiredBandwidths="29,29,29,29,29,29,29,29" displayTitle="French (PGS)" extendedDisplayTitle="French (PGS)"> </Stream>
<Stream id="31557" streamType="3" codec="pgs" index="13" bitrate="0" language="French" languageTag="fr" languageCode="fra" requiredBandwidths="20,20,20,20,20,20,20,20" displayTitle="French (PGS)" extendedDisplayTitle="French (PGS)"> </Stream>
<Stream id="31558" streamType="3" codec="pgs" index="14" bitrate="23" language="German" languageTag="de" languageCode="deu" requiredBandwidths="36,36,36,36,36,36,36,36" displayTitle="German (PGS)" extendedDisplayTitle="German (PGS)"> </Stream>
<Stream id="31559" streamType="3" codec="pgs" index="15" bitrate="0" language="German" languageTag="de" languageCode="deu" requiredBandwidths="36,36,36,36,36,36,36,36" displayTitle="German (PGS)" extendedDisplayTitle="German (PGS)"> </Stream>
<Stream id="31560" streamType="3" codec="pgs" index="16" bitrate="40" language="Spanish" languageTag="es" languageCode="spa" requiredBandwidths="52,52,52,52,52,52,52,52" displayTitle="Spanish (PGS)" extendedDisplayTitle="Spanish (PGS)"> </Stream>
<Stream id="31561" streamType="3" codec="pgs" index="17" bitrate="6" language="Spanish" languageTag="es" languageCode="spa" requiredBandwidths="121,121,121,121,121,121,121,121" displayTitle="Spanish (PGS)" extendedDisplayTitle="Spanish (PGS)"> </Stream>
<Stream id="31562" streamType="3" codec="pgs" index="18" bitrate="19" language="Dutch" languageTag="nl" languageCode="nld" requiredBandwidths="28,28,28,28,28,28,28,28" displayTitle="Dutch (PGS)" extendedDisplayTitle="Dutch (PGS)"> </Stream>
<Stream id="31563" streamType="3" codec="pgs" index="19" bitrate="22" language="Norwegian" languageTag="no" languageCode="nor" requiredBandwidths="32,32,32,32,32,32,32,32" displayTitle="Norwegian (PGS)" extendedDisplayTitle="Norwegian (PGS)"> </Stream>
<Stream id="31564" streamType="3" codec="pgs" index="20" bitrate="17" language="Swedish" languageTag="sv" languageCode="swe" requiredBandwidths="25,25,25,25,25,25,25,25" displayTitle="Swedish (PGS)" extendedDisplayTitle="Swedish (PGS)"> </Stream>
<Stream id="31565" streamType="3" codec="pgs" index="21" bitrate="63" language="English" languageTag="en" languageCode="eng" requiredBandwidths="68,68,68,68,68,68,68,68" displayTitle="English (PGS)" extendedDisplayTitle="English (PGS)"> </Stream>
<Stream id="31566" streamType="3" codec="pgs" index="22" bitrate="51" language="Danish" languageTag="da" languageCode="dan" requiredBandwidths="58,58,58,58,58,58,58,58" displayTitle="Danish (PGS)" extendedDisplayTitle="Danish (PGS)"> </Stream>
<Stream id="31567" streamType="3" codec="pgs" index="23" bitrate="53" language="Finnish" languageTag="fi" languageCode="fin" requiredBandwidths="59,59,59,59,59,59,59,59" displayTitle="Finnish (PGS)" extendedDisplayTitle="Finnish (PGS)"> </Stream>
<Stream id="31568" streamType="3" codec="pgs" index="24" bitrate="52" language="French" languageTag="fr" languageCode="fra" requiredBandwidths="63,63,63,63,63,63,63,63" displayTitle="French (PGS)" extendedDisplayTitle="French (PGS)"> </Stream>
<Stream id="31569" streamType="3" codec="pgs" index="25" bitrate="51" language="German" languageTag="de" languageCode="deu" requiredBandwidths="56,56,56,56,56,56,56,56" displayTitle="German (PGS)" extendedDisplayTitle="German (PGS)"> </Stream>
<Stream id="31570" streamType="3" codec="pgs" index="26" bitrate="51" language="Dutch" languageTag="nl" languageCode="nld" requiredBandwidths="68,68,68,68,68,68,68,68" displayTitle="Dutch (PGS)" extendedDisplayTitle="Dutch (PGS)"> </Stream>
<Stream id="31571" streamType="3" codec="pgs" index="27" bitrate="46" language="Norwegian" languageTag="no" languageCode="nor" requiredBandwidths="57,57,57,57,57,57,57,57" displayTitle="Norwegian (PGS)" extendedDisplayTitle="Norwegian (PGS)"> </Stream>
<Stream id="84853" streamType="3" codec="pgs" index="28" bitrate="49" language="Swedish" languageTag="sv" languageCode="swe" requiredBandwidths="61,61,61,61,61,61,61,61" displayTitle="Swedish (PGS)" extendedDisplayTitle="Swedish (PGS)"> </Stream>
</Part>
Thank you! I will for ward this.
thanks Otto
any help would be great no idea why th TV app has suddnely done this. Been fine for 3 years and many updates put on the synology nas
thanks
Server Version#: 1.24.0.4930 on Unraid
Player Version#: 5.21.1 On LG C9
hello, I discovered that when a media is played containing several EAC3 audio tracks, the audio track played is not the one selected, for example in my audio settings the “French” track is selected while the audio track that is played is the English audio track, and vice versa. I was able to solve this problem by disabling the “Dolby Digital Plus (EAC3)” option in the audio settings of the application. Could you please fix this ?
Hi there Raiiyzen
thanks for replying .That is a good solution but then we all suffer as we cannot play the audio to its maximum sound quality.
everything was fine until the plex update on my NAS was installed this week.
I have a similar problem with the LG webos client since updating my Synology Plex Server to Version 1.24.0.4930. I always have german and english audio added. Since last week it always plays english audio and no longer the german track, no matter what language i chose manually.
must be that the new update has messed with LG updates
thanks for your help
Seems like I have the same problem. I’ve reported it here: LG app plays a different audio track than what is selected
Could you produce a small sample file which reproduces this behaviour? Generating Sample Files from Media | Plex Support
One of the developers would like to have it for recreating the issue.
Use one of the movies where it happens for you, please.
Then upload it to e.g. GDrive and send me the download link per PM.
