Last Two Updates Break Playback of LiveTV Using HDHomeRun CONNECT 4K
Server Version#: v1.41.0.8994-f2c27da23-x86_64 & v1.41.0.8992-8463ad060-x86_64
Player Version#: ANY (ROKU) (AppleTV) (PLEX Media Player for Windows) Etc…
Roll-Back to v1.40.5.8921-836b34c27-x86_64 Fixes the Issue.
Thank you! I didn’t have the revision you quoted, but I had 1.40.4.8679-424562606. Rolling back seems to have fixed the problem (I need some more testing from clients on the WAN side, but LAN clients are fixed now). I need to put in a bug report, because PMS is clearly broken! I don’t know where to submit, or where Plex developers listen, but this needs fixing.
Regards,
Dean
Any updates on if this will be fixed in an upcoming version?
After deleting and re-adding my DVR in Plex settings, everything returned to normal. Although Plex warns that you may lose scheduled recordings, I didn’t lose any. I had also deleted and re-added my TV Shows folder, based on advice from someone with the same issue. If deleting the DVR alone doesn’t resolve the problem, try deleting the TV Shows folder first, then re-add the DVR.
