Server Version#: 1.19.1.2645
Player Version#: 4.22.3
I’ve several movies that need to be matched, but when I try to fix the matches, I see this:
I would think that it’s connectivity issue, but the ‘ribbon’ is displaying, so the list is at least partially rendering.
May I have the DEBUG logs ZIP file please?
No way to know what’s happening without them.
If something is indeed wrong, I’ll find it.
Absolutely. I went through the motions on that screen before exporting them, so hopefully its of use.
Plex Media Server Logs_2020-04-09_19-49-28.zip (2.9 MB)
Found a problem.
Naming of the media doesn’t look the best either.
Apr 09, 2020 14:59:15.198 [0x81085d000] DEBUG - Reconnecting item 6790 with item 7 in playlists.
Apr 09, 2020 14:59:15.200 [0x81085d000] DEBUG - We have a matching item 7 for the item we just set a GUID on (6790) '' (index: 1)
Apr 09, 2020 14:59:15.201 [0x81085d000] DEBUG - Matching 'Aladdin' (ID 7) with agent
Apr 09, 2020 14:59:15.207 [0x81085d000] DEBUG - Issuing search query: http://127.0.0.1:32400/system/agents/search?mediaType=1&id=7&identifier=com.plexapp.agents.imdb&duration=5444897&filename=%252Fmedia%252Fmovies%252Fmovies%252FAladdin%2520Diamond%2520Edition_t08%252Emkv&lang=en&openSubtitlesHash=d432b2fa5f8903ec&plexHash=854af1cde6d601565769034022bfde84d50a0a0a&name=Aladdin%20Diamond%20Edition%20T08
Apr 09, 2020 14:59:15.207 [0x81085d000] DEBUG - HTTP requesting GET http://127.0.0.1:32400/system/agents/search?mediaType=1&id=7&identifier=com.plexapp.agents.imdb&duration=5444897&filename=%252Fmedia%252Fmovies%252Fmovies%252FAladdin%2520Diamond%2520Edition_t08%252Emkv&lang=en&openSubtitlesHash=d432b2fa5f8903ec&plexHash=854af1cde6d601565769034022bfde84d50a0a0a&name=Aladdin%20Diamond%20Edition%20T08
Apr 09, 2020 14:59:15.208 [0x80baff700] DEBUG - Request: [10.0.0.17:31423 (Subnet)] GET /system/agents/search?mediaType=1&id=7&identifier=com.plexapp.agents.imdb&duration=5444897&filename=%252Fmedia%252Fmovies%252Fmovies%252FAladdin%2520Diamond%2520Edition_t08%252Emkv&lang=en&openSubtitlesHash=d432b2fa5f8903ec&plexHash=854af1cde6d601565769034022bfde84d50a0a0a&name=Aladdin%20Diamond%20Edition%20T08 (6 live) GZIP Signed-in
Apr 09, 2020 14:59:15.208 [0x80baff700] DEBUG - Completed: [10.0.0.17:31423] 401 GET /system/agents/search?mediaType=1&id=7&identifier=com.plexapp.agents.imdb&duration=5444897&filename=%252Fmedia%252Fmovies%252Fmovies%252FAladdin%2520Diamond%2520Edition_t08%252Emkv&lang=en&openSubtitlesHash=d432b2fa5f8903ec&plexHash=854af1cde6d601565769034022bfde84d50a0a0a&name=Aladdin%20Diamond%20Edition%20T08 (6 live) GZIP 0ms 357 bytes
Apr 09, 2020 14:59:15.208 [0x81085d000] DEBUG - HTTP 401 response from GET http://127.0.0.1:32400/system/agents/search?mediaType=1&id=7&identifier=com.plexapp.agents.imdb&duration=5444897&filename=%252Fmedia%252Fmovies%252Fmovies%252FAladdin%2520Diamond%2520Edition_t08%252Emkv&lang=en&openSubtitlesHash=d432b2fa5f8903ec&plexHash=854af1cde6d601565769034022bfde84d50a0a0a&name=Aladdin%20Diamond%20Edition%20T08
Apr 09, 2020 14:59:15.208 [0x81085d000] DEBUG - -1: ()
Apr 09, 2020 14:59:15.208 [0x81085d000] DEBUG - * Score: -1 ()
Apr 09, 2020 14:59:15.208 [0x81085d000] DEBUG - Refreshing metadata for 'Aladdin' (agent: )
Apr 09, 2020 14:59:15.208 [0x81085d000] DEBUG - Refreshing GUID: ''
Apr 09, 2020 14:59:15.208 [0x81085d000] DEBUG - HTTP requesting GET http://127.0.0.1:32400/system/agents/update?mediaType=1&force=1&respectTags=0&guid=&id=7
Apr 09, 2020 14:59:15.209 [0x80baff700] DEBUG - Request: [10.0.0.17:21857 (Subnet)] GET /system/agents/update?mediaType=1&force=1&respectTags=0&guid=&id=7 (6 live) GZIP Signed-in
Apr 09, 2020 14:59:15.209 [0x80baff700] DEBUG - Completed: [10.0.0.17:21857] 401 GET /system/agents/update?mediaType=1&force=1&respectTags=0&guid=&id=7 (6 live) GZIP 0ms 357 bytes
Apr 09, 2020 14:59:15.209 [0x81085d000] DEBUG - HTTP 401 response from GET http://127.
The server’s credentials don’t match what Plex.tv is expecting.
Is the server signed in?
The name should include the year. Aladdin (1996) or Aladdin (2019) to avoid the ambiguity.
It seems that it is, I’ve checked through plex.tv & through the local IP. Would me changing the IP address affect this? Or do I need to sign out and back in again?
Update - Signed out and back in with no changes. The server is also showing up under online sources with the correct info.
How is the file named? (exactly please).
That’s important.
I’m trying to dig down through .
Also, did any part of this installation come from/originate on a Windows host?
Here’s the relative path, name included: /media/movies/movies/Aladdin Diamond Edition_t08.mkv
The server is a Freenas Plugin, so nothing has come from Windows. The previous server (same name) was on Ubuntu.
Lastly, this issue isn’t unique to this specific movie, its for any movie that I attempt to fix matches for.
Hope that helps!
