Latest Upgrade has some MAJOR FLAWS! This is REPORTED with additional info
To TECH support only!!! NEW UPDATED info*: *someone at PLEX changed the metadata on something that CAUSED MAJOR PROBLEMS!!! This is a FACT! Therefore, NOBODY should ever change the metadata on programs that use or filter metadata, because that action has MAJOR negative consequences!
My AWARD WINNING techie daughter changed the metadata back to the way it should be and straightened out the problems that PLEX TECHS caused!
IF ANYONE ELSE IS HAVING PROBLEMS WITH YOUR RECEPTION &/or CONTENT ON PLEX, IT COULD BE CAUSED BY THE SAME PROBLEM!!
Further… Automatically downloading PLEX updates is ill-advised! If your system is working properly, WAIT to see what possible problems may service, before updating.
Server Version#:
Player Version#: LG TV’s (2)
strong text
The last upgrade added some much stronger ability to record lower band channels, for lack of a better term, that I wasn’t able to record before and LOVE! HOWEVER…
There seems to be a BIG glitz in the LG TV’s that is allowing duplicate copies of some Netflix movies, ETC,. to load to my Mac.
PLEASE> PLEASE< PLEASE address this subject, because if I delete one copy, both are gone!
PLEASE introduce some BETA TESTERS to preview upgrades for glitches BEFORE RELEASE…
If you need more technical info, my Award winning TECHIE daughter could help.
No tech support… but if you want a reaction/response/fix you might want to describe what’s actually changed / no longer working.
While it’s good to know your daughter fixed it for you, your post is not particularly clear/helpful.
