Libraries are shared but nothing is showing up in menu
Hello,
My friend is sharing his Plex server with me. It has been working fine for years up until this point. He has several libraries shared and I can still confirm that by looking under his Plex username in “Manage Library Access.” However, where I used to see his server name and the list of libraries being shared (in the left-hand main menu), now nothing is shown. I only see my own server’s libraries.
I have tried four different Plex apps all with the same results:
Roku, Plex Web, Plex for Windows app and Plex for Android app.
A little background…
We were recently having a problem with my access going through Plex Relay to his server due to a firewall misconfiguration, but we believe we got Direct access working again. But, after fixing that problem I was unable to stream from his server at anything faster than 2 Mbps. We were testing a few things but found nothing and my friend reported that no one else was going through the Relay any longer and he doesn’t either when using a VPN to remote connect back to his server. They also all were able to stream at full speeds (much greater than 2 Mbps). Then suddenly I lost all access to his server. Seem liked he kicked me off the server but as I said I can still see that he is sharing libraries with me in the “Managed Library Access.”
Have you checked if the libraries of your friends server are simply no longer pinned to your sidebar / main menu? They should still be showing in the More section of that sidebar.
Hi Tom80H,
Yes, I did check under “More” and his server is not listed there at all. Very strange.
Does this issue persist if you sign out from the app and back in?
No luck. I just signed out, closed all open browsers, reopened and signed in again. Problem persists.
This problem is across multiple players so it seems more like an account issue:
Roku
Plex Web
Plex for Windows
Plex for Android
Your friend’s server is showing as “not published”.
So there is nothing you can do on your side. He has to sort out his remote access.
Thank you!
Is there anything I can point him to, or will it be fairly obvious on the Remote Access page?
Looks like he has set up a new machine. Just wait a few hours for the changes to propagate.
On your side you could force your clients to refresh their informations by “switching users” back and forth.
The problem started occurring last night, so I believe it has been several hours as far as I can tell. I have tried switching users, but with try again.
I’m reaching out to him as well to get more details on his end.
From my friend:
I moved my preferences.xml to a backup in an effort to resolve any cached problems. If that qualifies as “a new machine” then… ok. I have no problem seeing my server over 5G on my phone.
The cached problems he is referring to are when we were trying to solve the Plex Relay connection and get a Direct connection going.
Not sure why he is able to connect to his server outside his home, but I can’t. I tried switching users a few times just now.
That causes the server to get a new machine ID, which is as good as a “new server”.
As a result, all shares of the “old server” are void.
He has to explicitly grant his friends (i.e. you, among others) access to this new server again.
If he were to restore the old preferences.xml file, should things go back to the way they were?
Maybe. But he might have to delete his old certificate file, because the old server has a different one assigned to it.
Plex data folder/Cache/cert-v2.p12
Thank you, passing that along. Fingers-crossed. Going to try later today is the word.
so, as that friend in question, I’ve restored my old Preferences.xml but likely need my cert refreshed.
“incomplete TLS handshake from XXX: sslv3 alert bad certificate”
The root cause of the original issue was me moving from OpenWRT to pfSense and forgetting about the DNS rebinding change. That has been resolved.
