Hi all, I used Plex on an old Mac without any issues but since it no longer supports the app (it’s too old ), I was about to set up Plex on my current Mac but I can’t figure out why the library menu is missing when I open it. Please, anyonw could help me?
The funny thing is that when I first opened it, I wasn’t asked to add a library.
I did disable online media sources.
I can’t pin my libraries to the sidebar because I can’t see them. When I click More on the left menu I just get this:
Yes it does (ss below).
But when I used Plex on my other old Mac I didn’t have an account. I just signed up recently and wanted to start from scratch, that’s why I found it funny that I wasn’t asked to set up a location for my library at the beginning.
Is it possible, that your server is (still) using a different plex account instead?
Please use the web app and access your server settings. You should find the information under
Settings - [Server name] - General
You can’t install the server on a mere hard drive.
Or was it a Drobo?
I think you already had an account. You just forgot about it. Your server is still running under this account. And that is the reason why this new player doesn’t have access to it.
I took a look at your account (the one you are using to access this forum). TGhere is no server signed into it.
Can you look at yome older email accounts, if you find some mailings from Plex, maybe even a clue what your old password might have been?
