Library Scan Crashes Streams
Server Version#: 1.21.1.3876
Player Version#:4.49.2
Hey guys,
I am having issues with plex library scanner crashing my streams. It has been happening for quite some time now and I have not found a permanent solution. My temporary fix is to disable automatic scanning and set periodic library scan to 12 hours. The affected devices as far as I can tell are chromecasts, web, and xbox ones. The built in bandwidth monitor drops from around 50mbps to almost zero and most streams are die. Samsung tvs seem to reconnect without completely losing the stream. I will provide logs for 2 occurrences roughly around the time. The first at 1:32AM Jan 10th, the second 2:14AM Jan 10thPlex Media Server Logs_2021-01-10_01-34-16.zip (3.9 MB) Plex Media Server Logs_2021-01-10_02-15-52.zip (3.8 MB)
Let me know if you guys need anymore info or logs and I am able to reproduce this issue at anytime by forcing a scan.
I just ended up deleting all plugins, running installer repair and rebooting. I take it might be corruption or bad plugins.
