Limit remote stream bitrate not working
Server Version#: 1.16.1.1273
Player Version#: 3.104.1
I have ~6Mbps uplink, but I share my library with my immediate family, and a few select friends. I have the “limit remote stream bitrate” set to 3Mbps 720p. At this, I would expect that any remote stream would use ~half of my uplink, allowing me to still use the rest.
However, I’ve noticed lately when I’m playing Xbox online, my game gets really laggy and rubberbands a lot. If I pull up my Plex dashboard, sure enough, someone’s streaming, and the peaks are using up the full 6Mbps. If I kill the server entirely (cruel, I know), everything is smooth on my game.
This leads me to believe that the server setting is not respecting the limit that I set. I realize that a video stream isn’t a constant stream, that it breaks up the pieces and sends them over in bits - hence the spikes in the blue line on my dashboard. However, given my setting, those spikes should NEVER exceed 3Mbps, correct? Then why is it exceeding them?
The setting is the Average, so it will still burst to the maximum of you upload speed. Does your router have a form of QOS?
That setting only affects the bitrate of the output file, not the actual connection. If you want to limit the bandwidth of the connection, set your internet upload speed.
