Limited metadata for Movies and TV
Server Version#: 1.12.2.4929 (FreeNAS-11.1-U6.3)
I’m recently installed Plex as a FreeNAS plugin. But I am unable to get a complete metadata update for Movies or TV.
In both cases the metadata grabber populates the Title and Sort Title Fields and I can find a group of correct posters. All other fields remain blank. For TV All episodes are given the episode number as a title and I get no information about the individual episodes.
For troubleshooting I have created a test server with only a few Videos. I am attaching to logs to this message.Plex Media Server Logs_2019-01-01_11-53-30.zip (399.5 KB)
Your PMS seems to be unable to save the metadata due to lacking permissions:
Jan 01, 2019 11:09:11.101 [0x80a13c400] ERROR - Error creating directory "/var/db/plexdata/Plex Media Server/Media/localhost/9": boost::filesystem::create_directories: Permission denied: "/var/db/plexdata/Plex Media Server/Media/localhost"
Jan 01, 2019 11:09:11.101 [0x80a13c400] ERROR - Error creating directory "/var/db/plexdata/Plex Media Server/Media/localhost/9/aa98c0dc9f71edd0bc6dee4ec110b2f2ca5e721.bundle/Contents": boost::filesystem::create_directories: Permission denied: "/var/db/plexdata/Plex Media Server/Media/localhost/9/aa98c0dc9f71edd0bc6dee4ec110b2f2ca5e721.bundle"
Jan 01, 2019 11:09:11.102 [0x80a13c400] ERROR - Error creating directory "/var/db/plexdata/Plex Media Server/Media/localhost/9": boost::filesystem::create_directories: Permission denied: "/var/db/plexdata/Plex Media Server/Media/localhost"
Jan 01, 2019 11:09:11.102 [0x80a13c400] ERROR - Error creating directory "/var/db/plexdata/Plex Media Server/Media/localhost/9/aa98c0dc9f71edd0bc6dee4ec110b2f2ca5e721.bundle/Contents": boost::filesystem::create_directories: Permission denied: "/var/db/plexdata/Plex Media Server/Media/localhost/9/aa98c0dc9f71edd0bc6dee4ec110b2f2ca5e721.bundle"
Jan 01, 2019 11:09:11.102 [0x80a13c400] ERROR - Error creating directory "/var/db/plexdata/Plex Media Server/Media/localhost/9/aa98c0dc9f71edd0bc6dee4ec110b2f2ca5e721.bundle/Contents/Thumbnails": boost::filesystem::create_directories: Permission denied: "/var/db/plexdata/Plex Media Server/Media/localhost/9/aa98c0dc9f71edd0bc6dee4ec110b2f2ca5e721.bundle/Contents"
Are you sure the user running Plex has write access to that directory? Did you install the plugin “as is” or did you change anything during/after installation?
The Media directory doesn’t exist by default so I created it as a mount point. In doing so it was created with the wrong permissions. I did not realize that plex needed write permissions on the Media directory.
I’ve corrected the permissions everything seems to be working now.
Thanks.
You’re welcome. Please go ahead and mark the solution as such. :handshake:
