My system crashed after a Windows update. Since I was unable to recover I had to do a clean install - windows, Plex, etc. The media files on the separate drives are still there.
Now that my PC is now up and running I’ve reinstalled Plex Server but can’t link to the media files on the other drives. I have a Plex Pass account. Help!!
Soooo… where exactly are you getting stuck?
You have re-created your libraries and get to the point where you add / assign a folder for that library? Is that drive not accessible / visible from within that dialog?
when you get to the part of claiming your server… make sure to login with your existing account and not to sign-up a new one
During the installation you’ll be provided with an option to name your server and to create your initial libraries (you can add more later) – and most importantly to link the new server to your Plex account.
