Live TV and DVR
I have been trying for days to get the recording function to work again on my freeNAS PMS using an hdhomerun. No matter what I do I cannot get the recordings to start. They always error out with a “no write access to destination” error.
The perms and ownership on the dirs are correct. This used to work but since upgrading its stopped.
freeNAS 11.2 U5
Plex 1.16.1.2373
Can somebody please help?
r
I’m having the same issue. Did you ever resolve it?
No i havent. Sure would like to hear from somebody with a similar configuration. This used to work fine until I upgraded.
Just in case, does upgrading 1.16.2 help?
This all started when I upgraded several months ago to a 1.15 version and hasnt worked since.
I have tried everything i can think of including going back to that original version. Its a shame because it worked really well when it was working.
Silicon dust is no help, and i cant get help from the plex folks
I’ve been wrestling with a problem wit the DVR in the upgrade between 1.15 and 1.16. I’m running on a Windows 2013 server. But, my fix might still be worth a try. Downgrade to 1.15 and delete your DVR in Plex. Then upgrade to 1.16 and add a new DVR.
I have been having similar difficulties for some time now though not with all recordings. It appears to be somewhat random, some record and process correctly while others fail with “cannot move media…”
While investigating, I have discovered that the failed episodes and movies were recording into a .grab folder inside the recycle bin on my synology. The successful ones are recorded into their correct respective .grab folders in the libraries. I can actually see the file “growing” in the recycle bin examples. Also, it has been difficult to identify because very shortly after failing, the “bad record” is removed completely from the recording schedule view covering up the fail.
I cannot see why plex would create and point to temp folders inside the recycle bin. BTW, giving plex full permissions in the recycle bin did not resolve the post-processing which implies the possibility of unequal pointers at different points in the processing… Let me know where you would like me to send logs if you need them.
Thanks,
Frank
Plex Media Server Logs_2019-07-21_11-03-47.zip (4.6 MB)
Here are my logs, just found the icon for this, still learning the forums…
Thanks,
Frank
My installation is in a freenas jail. As I said I reinstalled the version which was working which didnt help. Where did you find your logs?
thanks
bring up plex web interface, goto to settings, troubleshooting, and select download logs. Plex will zip them up and let you select where to save…
I’ve also had recording failures, stuttering and even errors locking things up when watching live TV. Given all the other issues such as having to now move to a paid EPG provider, having to downgrade Plex to an earlier version just to reset your DVR devices before having to redo the Plex upgrade and what appears to me to be a hard set limit of 11 categories to choose from for recording destinations (I have over 20 so half aren’t available to select in the drop down menu), it appears to me a lot more resources need to allocated to the Live TV/DVR functions of Plex to bring it up to a suitable level as far as feature implementation and quality control are concerned.
Each of the last few upgrades have caused more issues than benefits.
This is happening to me too. It stopped being able to write to my network drive after upgrading to 1.16.3. It is driving me nuts.
Is anybody from PLEX reading these messages, or are we totally on our own? They gladly take the money for the plex pass I have purchased, but dont provide any sort of support. Sure would be nice to have a official answer, as I am sure we are not the only ones seeing this issue
yes, the issue is presently well-known.
You probably have to wait for the next release : since the Version 1.16.3.1451, it works fine.
Nevertheless, you will have to delete the old recorder and reconfigure a new one with the new EPG/channel provider.
You can find the answer on many other thread because it is a general issue applying on each OS.
For example here : DVR Setup stuck at 0%? I cannot watch Live TV or set it up either.
For my issue with the recordings going directly to the recycle bin, there has been no change. I am now on Version 1.16.3.1402. Today, 2 out four episodes of 3rd Rock recorded ok, another 2 went straight inot the recycle bin and I have to assume “could not move media” because the recording screen no longer shows errors for more than a few minutes.
If the issue is presently well known, why not fix it? This has been broken since a 1.15 version. I have tried to delete the device, upgrade, install new, it doesnt matter. Upgrading to the latest version also did nothing.
Has anyone taken a look at this yet? The problem is getting worse, I even removed PLEX completely from my Synology and re-installed. First day, recorded 8 shows and 2 recorded dirrectly into the recycle bin, next day 10 shows, 5 went into the recycle bin. Today I recorded 12 shows and 8 went into the recycle bin???
This thread has been going for a while.
Could I have some fresh logs please after such a recording failure and using current version of Plex Media Server which is 1.17.0.1709
https://support.plex.tv/articles/201643703-reporting-issues-with-plex-media-server/
https://support.plex.tv/articles/200250417-plex-media-server-log-files/
Thanks, I am definitely running Version 1.17.0.1709… One more note, while I was rebuilding my NAS Plex server, I moved recording to my Shield Plex Server with the same results, that was a week ago however. If you need those logs I can move some of my recording schedule to the Shield again and get fresh logs. I have attached my logs from the Synology server.Plex Media Server Logs_2019-09-27_08-31-42.zip (8.5 MB)
