Live TV and recorded TV playback stutter, buffering, and pixelation using Plex Server 1.18.0.1846
Reverting back to an older version worked for me as well.
Phew, I thought the stuttering was my network or the HDHomerun’s, I’ve been rebooting things, unplugging and re-plugging like mad. Now spotted this thread am about to rollback!!
I’m not updating until I get the all clear!
Do you have full logs with debug logging enabled?
If you know the issue arises in the first few minutes, you could chop the file and give us the first x minutes.
See https://support.plex.tv/articles/201035968-generating-sample-files-from-media/
with a .ts file it should be to just chop the file
Thanks for the samples and the logs
For these logs when direct streaming to the Roku, was there an issue leading to buffering and/or pixilation?
Yes, there was pixelation and stuttering during the 10-15 minutes I watched. As soon as I quit the stream, I generated the logs and uploaded them.
@Noah0504 Thank you - I have referred the sample and logs to our development team
Also the logged errors identified by @c.megalodon - but would need full debug logs
I am having the same issue with 1.18.0.1846. recordings pixelate and skip recording from an HD Homerun. 1906 release today has maybe made things a little better but programs are unwatchable.
I’m running on windows server 2012 R2. The files have the same issue when opened and watched on a PC so this seems to be a recording issue rather than a playback issue. Have tried playing back on Shield, android phone, web client and AFT.
@sa2000
I am having an issue with Live TV it would seem on my apple tv only. When i tune in a channel, the picture freezes and pixilates. My plex server dashboard says that the apple tv is buffering. I have attached a snip of what the dashboard shows. The dashboard reports that the apple tv is using 10Gbps. I know that is not possible, but should it say that? My Fire TV seems to do fine. The issues i am seeing are on Plex server version 1.18.0.1913. My tuner box is a Hauppauge Quad. As soon as i revert back to version 1.17.0.1841, everything works great. I have posted server logs, and can provide my token if needed. I installed version 1.18.0.1913 again, so that i can provide more logs or any other information if needed. I know that my apple tv will not be usable will i am running server version 1.18.0.1913, but i am willing to take one for the team in the name of getting this worked out. Please help.
10GBPS%20apple%20tv|690x544
Plex Media Server Logs_2019-10-09_19-18-43.zip (4.4 MB)
Thank you - I have added your diagnostics to the set we had from other users
Hi folks, a quick update:
We have been looking into the issue and haven’t been able to reliably reproduce internally. Would anyone be around in ~4 hours to help us debug this live? I should have a series of builds available to help us narrow down where the issue was introduced.
Thanks!
I could potentially be available. I’ll be at work in about an hour, but will be there early, so I might have 1-2 hours to help.
I believe Plex made some transcode changes to 1.18. One may consider whether PMS servers affected have NVidia GPUs. I recently added an NVidia card to my server which has been working great under V1.17. If only select users are experiencing this issue could it be based on how their PMS system is configured for transcoding? - GPU vs no GPU, Background transcoding preset, etc… Just a thought.
@Noah0504 - what platform are you running on? I have 3 builds available that I’d love you to take for a quick spin.
Running on Linux (Debian 64-bit). And I’m available to test now.
I’ve reached out in a DM. Chat in there :slight_smile:
Thank you @Noah0504 and @StSimm1 for working on this! If needed, early next week I’m in for any testing/assistance I can provide. I’m bummed I can’t be available now.
I’m having the same issue. Ubuntu 18.04, 2400G, HDHomerun. Library on internal HDD. Updated Tuesday night. Ever since, skipping every 5-40 seconds. Recordings viewed in VLC has same problems. Recordings from before the upgrade seem to play fine. PMS - only plays to itself, no streaming devices. Happy to provide logs etc if needed, but I’m heading to work and unavailable until evening.
Please backup your database before installing
Please take this build for a spin, it should help us work out where the issue is
macos
https://artifacts.plex.tv//plex-media-server-experimental/1.18.0.1936-d100a9cd2/macos/PlexMediaServer-1.18.0.1936-d100a9cd2-x86_64.zip
windows
https://artifacts.plex.tv//plex-media-server-experimental/1.18.0.1936-d100a9cd2/windows/PlexMediaServer-1.18.0.1936-d100a9cd2-x86.exe
debian
https://artifacts.plex.tv//plex-media-server-experimental/1.18.0.1936-d100a9cd2/debian/plexmediaserver_1.18.0.1936-d100a9cd2_amd64.deb
unraid
https://artifacts.plex.tv//plex-media-server-experimental/1.18.0.1936-d100a9cd2/unraid/PlexMediaServer-1.18.0.1936-d100a9cd2-x86_64.txz
freebsd
https://artifacts.plex.tv//plex-media-server-experimental/1.18.0.1936-d100a9cd2/freebsd/PlexMediaServer-1.18.0.1936-d100a9cd2-FreeBSD-amd64.tar.bz2
Same here
I have tried the windows one and it is showing similar pixelation and skipping. The Audio seems a bit more consistent but it is still dropping out when it skips forward a second or so.
Shout if you need logs or sample.
