This is the worst thing about Plex. You kindly file a report as nicely as you can and a month later you’ve not even got as much as an acknowledgement that your report was even looked at. I honestly would pay twice as much (or more) if I could get decent Support for Plex, because then I wouldn’t have to have a backup option for when Plex just can’t do the things it should do.
I AGREE SO MUCH!!!
I bookmarked this page and come back daily. I filed an EPG report more than a month ago. @sa2000
I am sorry that I have to catch up - i got up to this post in this topic
This forum thread is in my backlog of threads / issues to process
In Chicago, we have some new low power stations that are not yet in the Live TV EPG.
Information for plex server: USA/60532/Lisle, IL/server version 1.32.8.7639/epg local broadcast listings 120 channels.
Could you please add channels 3.1, 3.2, and 3.3 to the EPG?
3.1 is NEWSNeT (from Bridge News)
3.2 is SNHtv (from Bridge News)
3.3 is ShopHQ
This still hasn’'t been added to the EPG. Not sure if it’s worth another referral to Gracenote. Thanks!
Issue
Thank you for the update. The EPG UI is not friendly, where I had to add multiple zip codes and pray that they have the channels I need to complete the TV listing. I literally spent 5 hours looking at Google Map and entering multiple zip codes (literally, major cities in the USA, not just the West Coast) in Plex. So far, I couldn’t complete the TV listing. This has been frustrating, and I believe this UI and workflow should be improved.
What zip codes should I enter to complete the TV listing? Thank you so much for your time and help!
Spec
- Plex Media Server Version: 1.40.0.7775 (Linux)
- TV Tuner: Hauppauge WinTV-dualHD
How to produce this issue
- See https://www.youtube.com/watch?v=buikbJO2rKs
- Go to
Live TV & DVRunder Manage - Click
Set Up Plex DVR - Select
Antenna, SelectUS, Enter95054zip code (returns 48 matched channels) - Click
Next - Click
Add channels from another lineup/locationto add 4 additional zip codes:- Long Beach (Los Angeles), CA -
90712(1 matched channel) - Chico-Redding, CA -
95973(2 matched channels) - Reno, NV -
89502(1 matched channel) - Fresno, CA -
93704(3 matched channels)
- As a result, 55 out of 63 channels got matched.
- I removed all the irrelevant zip codes because they are too far from me. Otherwise, the TV listing would display incorrect logos and shows.
- Your EPG data is missing (by using only my zip code)
- 14.2 UniMas
- 16.1 ABHP
- 16.4 CornerS
- 16.5 QHTV
- 16.10 VNA TV
- 16.12 IBC-TV
- 16.14 GetThis
- 16.15 VNBC
- 16.16 VMTV
- 24.1 Diya TV
- 24.5 VietBay
- 24.6 VBS
- 24.10 JTV
- 24.11 QVC
- 24.12 QVC2
EPG Channel Matching 19063, USA Plex Media Server version 1,32,8,7639-7000:
No EPG for the following Channels:
15.1 WSJT
15.2 MOVIE
15.3 WALK
15.4 NTD
15.5 BVOVN
15.6 WEATHER
15.7 GEBTV
15.8 SHOPLC
25.4 INFO
39.2 CREATE
39.3 FRAN24
41.1 WDUM-LD
41.2 WD M-LD
41.3 WDUM-LD
41.4 WDUM-LD
41.5 WDUM-LD
41.6 WDUM-LD
41.7 WDUM-LD
44.4 WMCN.4
51.4 QVC2
60.1 WBPH-D1
60.2 WBPH-D2
62.1 WWSI-TV
62.2 EXITOS
69.1 WFMZ-HD
69.2 WFMZ-WC
69.3 WFMZ-ME
Feedback for Plex Team
I feel the whole UX should be thoughtfully reviewed and improved.
Channel Reporting: The current method of reporting missing channels through the forum is inefficient for both users and Plex support. Consider a more user-friendly and streamlined channel reporting system within the Plex interface itself.
Manual Workload: The current process seems manual and tedious for Plex support to handle reported issues. Streamlining the reporting and troubleshooting process can alleviate workload and improve efficiency, leading to better responses.
Feature requests:
EPG Flexibility: Allow users to mix custom EPG data (local or remote) with Plex’s EPG, enhancing user control and overcoming limitations of the single-source system. Given the difficulty of manually editing the SQLite3 file for EPG modifications.
Channel Enablement: Allow enabling channels even without Plex EPG data, as confirmed by working on a regular TV. Advocate for user freedom to access desired channels beyond EPG availability.
@sa2000. Thanks for working on this. This is a re-post due to no acknowledgment and it’s not fixed.
The lineup name : Local Bradcast Listings (69 channels)
Channel number and channel name 21.1 KRWB-HD
Your country US
Postal code 88310
Region/market USA
Version of Plex Media Server in use - Version 1.32.8.7639
Issue: There is no match for the channel and no listing that matches. It’s a straight simulcast of KWBQ. There is also no match/listing for KWBQ.
As a side note, using multiple listings when I set up the DVR is also not working. I used to do that as a workaround but then one day a few days ago the entire DVR listings showed up as “not found”. I deleted and tried to re-add the DVR and now it won’t allow multiple channel listings to be used.
Problem: Several channels have no info, display “Unknown Airing”
Lineup name: Local Broadcast
Channel number and names: See Screenshot below.
Country: USA
Postal Code: 55426
Region/Market: Twin Cities, MN
PMS version: 1.40.0.7775
Screenshot of issue:
Lineup:
Channel Numbers & names:
Can;t really use the provided link - if I go to Perth TV Guide - All TV Show times, All Channels - 9Entertainment and on this I select Perth for the location and then click on channels, I get this channel list
channel list on web page.txt (2.5 KB)
There are no ultra hd sport channel names listed and furthermore this list does not give the channel numbers. To get channels added to a lineup - in this case it is this lineup Freeview - Perth (58 channels) I would need channel numbers and channel titles and also a url or pdf from the provider that shows these channel numbers and channel names for that region.
I have not got to that post yet.
Your screenshot did not complete the upload.
I checked RabbitEars.Info for Joplin, Missouri and have asked Gracenote to add these channels
45.7 NTD America from KRLJ-LD
50.x channels from KJLN-LD
50.1 720p HRTLND Heartland
50.2 480i RTV Retro TV
50.3 480i REVN Rev'n
50.4 480i ACTION Action Channel
50.5 480i FAMILY The Family Channel
50.6 480i REVIVAL Revival TV Network
50.7 480i SHOPLC Shop LC
This has now been referred to Gracenote
My apologies, us young whippersnappers apparently don’t know how to use forums.
In any case much appreciated, my screenshot was just showing those channels in the plex UI.
The EPG for zip 75022 (Dallas/Ft. Worth TX market) still shows 68.3 as GRIT. It became LAFF almost 2 weeks ago. There are obviously cascading changes as GRIT moved …
The EGP for Local Broadcast Listings for USA zip code 88310 for channel 10.2 (FOX) now always just says: Football action from around the NFL instead of saying who is going to play. I realize in advance it’s dynamic but it gets resolved well before the broadcast…and it’s not getting resolved to who is actually playing. It’s been doing that for the last 4-5 weeks now. You can look up who is actually playing by going here:
https://www.krqe.com/fox-new-mexico-shows-specials/fox-new-mexico-tv-schedule/
…so the data is available. The CBS station above always shows who’s playing correctly.
Please kindly ask Gracenote to add the channel RAI 3 Südtirol to the following setup:
Country: Italy
Postal code: 39030
Lineup: DVB-T
Please note that the channel Rai 3 TGR Trentino Alto Adige already exists there, but it does not include the German part of local/regional broadcasts that can be found on the webpage: https://www.raisudtirol.rai.it/de/
When I download that txt file I can see Fox Sports UHD1 under Foxtel - Sport.
This is how it looks for me:
I believe they are using the same guide data as they also have a lot of the Foxtel logos missing, as mentioned in my other post you have not got to yet.
This should all be added to the Foxtel - Perth guide, not the Freeview - Perth guide.
Just checking back in on this since “Catchy” still isn’t available in the EPG for 13.5 (KOVRDT5)
Thanks again
Can you please ask Gracenote to update the Local Broadcast Listings for Zip Code 44136 Cleveland OH region channel mapping to include the following Channels:
13.1 WVIX-HD
13.2 This-TV
13.3 Ace-TV
14.3-newsnet
13.5 retro
13.6 Heart
16.1 Wrap D1
16.2 Wrap D2
16.3 Wrap D3
16.4 Wrap D4
35.2 Story
365.12 EMLW
44.1 WEKA-1
44.2 WEKA-2
44.3 WEKA-3
44.4 WEKA-4
44.5 WEKA-5
44.6 WEKA-6
44.7 WEKA-7
Plex version: 1.32.8.7639
Thank you
