I’m in the South West and BBC1 HD is also incorrectly tagged here! Postcode area PL20
Also I’m missing data for a few channels like some others have reported! There is data missing for BBC1 HD, ITV1 HD, Channel 4 HD and Channel 5 HD this evening for instance.
2 New Channels in the South Bend Indiana (Michiana) area
16.6 Oxygen
16.7 GetTV
Can you please get these added?
Thank you:
Thought i was going mad. Same issue here. Channel 4 listings for 9pm missing among others.
Thank you for your response. I am missing the EPG Channel data for these 34. channels. So I cannot add them. The TitanTV guide shows the channel data, so I know it’s available.
Zip code is 89138
It appears that schedules are only showing for Sundays. I have referred this to Gracenote
Thank You
I have referred this to Gracenote. Some post codes appear to be missing these channels. The one I checked earlier, 89101, does have the channels
I have looked into channel 4 and can see some TBAs.
| beginsAt (BST) | Duration (Mins) | endsAt (BST) | Title |
| Tue 09-May-2023 16:00 | 60 | Tue 09-May-2023 17:00 | To Be Announced |
| Tue 09-May-2023 20:00 | 60 | Tue 09-May-2023 21:00 | To Be Announced |
| Wed 10-May-2023 00:05 | 60 | Wed 10-May-2023 01:05 | To Be Announced |
| Wed 10-May-2023 02:00 | 55 | Wed 10-May-2023 02:55 | To Be Announced |
| Sat 13-May-2023 12:45 | 150 | Sat 13-May-2023 15:15 | To Be Announced |
I have referred this to our EPG ingestion team.
It is possible that there are late updates to the schedule
Thanks for that, you appear to be correct, just checked myself and it only shows for Sunday between 14:00 and midnight.
This has been referred to Gracenote
Perfect. I see the channels on the tuner but the channels of 34 have no matching epg channel data so plex does not add them due to no epg data. So thanks for sending the Gracenotes
Hello In Puerto Rico zip code 00627 the EPG is not mapping the correct channels. Example channel 2.11 does not have an associated EPG channel mapping. Also channel 4.3 has also incorrect channel label it is not mega TV
Is the TV Stations market for your zip code listed here RabbitEars.Info ?
Can you tell me which stations are broadcasting these channels
You could also get me a screenshot to show what your tuner is receiving for these channels - in DVR Settings / enabled channels view
Hello, thanks for fixing the postcode EPG data for DE73, for channel “101 BBC ONE EMid HD” I can select “001 BBC One East Midlands HD (BBC1EMHD)” as the guide data.
But the guide appears confused…
I deselected channel 001 as I don’t want it (its SD not HD), and chose 101 as above.
But I am seeing channel “001 BBC1EMHD” in my guide, and no channel 101.
It seems that 101 guide data is incorrectly set to London as below:
This should be the situation ideally:
Channel 001 is BBC1 EM SD, it should have SD data.
Channel 101 is BBC1 EM HD, it should have HD data.
I have referred this to our EPG ingestion team - highlighting these TBAs in schedules for 9th to 13th May
| channel # / callsign / title | beginsAt (BST) | Show |
| 1 : BBC1SWHD (BBC One South West HD) | Thu 11-May-2023 06:00 | To Be Announced |
| 1 : BBC1SWHD (BBC One South West HD) | Thu 11-May-2023 10:00 | To Be Announced |
| 1 : BBC1SWHD (BBC One South West HD) | Thu 11-May-2023 13:45 | To Be Announced |
| 1 : BBC1SWHD (BBC One South West HD) | Fri 12-May-2023 12:15 | To Be Announced |
| 1 : BBC1SWHD (BBC One South West HD) | Sat 13-May-2023 10:00 | To Be Announced |
| 1 : BBC1SWHD (BBC One South West HD) | Sat 13-May-2023 16:30 | To Be Announced |
| 1 : BBC1SWHD (BBC One South West HD) | Sat 13-May-2023 19:30 | To Be Announced |
| channel # / callsign / title | beginsAt (BST) | grandparentTitle |
| 101 : BBC1LDH (BBC One HD (England) Affiliate: BBC1) | Thu 11-May-2023 06:00 | To Be Announced |
| 101 : BBC1LDH (BBC One HD (England) Affiliate: BBC1) | Thu 11-May-2023 10:00 | To Be Announced |
| 101 : BBC1LDH (BBC One HD (England) Affiliate: BBC1) | Thu 11-May-2023 13:45 | To Be Announced |
| 101 : BBC1LDH (BBC One HD (England) Affiliate: BBC1) | Fri 12-May-2023 12:15 | To Be Announced |
| 101 : BBC1LDH (BBC One HD (England) Affiliate: BBC1) | Sat 13-May-2023 10:00 | To Be Announced |
| 101 : BBC1LDH (BBC One HD (England) Affiliate: BBC1) | Sat 13-May-2023 16:30 | To Be Announced |
| 101 : BBC1LDH (BBC One HD (England) Affiliate: BBC1) | Sat 13-May-2023 19:30 | To Be Announced |
| 103 : ITV1WHD (ITV West Country HD) | Tue 09-May-2023 04:05 | To Be Announced |
| 103 : ITV1WHD (ITV West Country HD) | Tue 09-May-2023 10:00 | To Be Announced |
| 103 : ITV1WHD (ITV West Country HD) | Tue 09-May-2023 20:00 | To Be Announced |
| 103 : ITV1WHD (ITV West Country HD) | Thu 11-May-2023 10:00 | To Be Announced |
| 103 : ITV1WHD (ITV West Country HD) | Fri 12-May-2023 12:30 | To Be Announced |
| 103 : ITV1WHD (ITV West Country HD) | Fri 12-May-2023 19:30 | To Be Announced |
| 103 : ITV1WHD (ITV West Country HD) | Fri 12-May-2023 20:00 | To Be Announced |
| 104 : C4HD (Channel 4 HD) | Tue 09-May-2023 16:00 | To Be Announced |
| 104 : C4HD (Channel 4 HD) | Tue 09-May-2023 20:00 | To Be Announced |
| 104 : C4HD (Channel 4 HD) | Wed 10-May-2023 00:05 | To Be Announced |
| 104 : C4HD (Channel 4 HD) | Wed 10-May-2023 02:00 | To Be Announced |
| 104 : C4HD (Channel 4 HD) | Sat 13-May-2023 12:45 | To Be Announced |
| 105 : CH5HD (Channel 5 HD) | Fri 12-May-2023 20:00 | To Be Announced |
correct - the channel numbers we go with are the ones from the EPG and not the Tuner
So in your case
Tuner channel 1 - disabled
Tuner channel 101 - matched to EPG channel 1 BBC One East Midlands HD
This will show as channel 1 and not 101 but will be using the BBC One East Midlands HD schedule from Gracenote
I have asked gracenote to re-open the issue relating to regional BBC1 HD channels as they added them as channel 1 and not 101
Ah OK.
Thanks!
All - please see this post Upcoming DVR program guide lineup changes for Australia, Canada and Europe/UK
Recreating all my planned recordings?
If this is the case, Plex DVR is dead to me.
Plex failed to implement keyword-based recordings since years.
R U kidding?
