Live TV EPG - The update you’ve been waiting for
Gracenote have corrected the Derby Post Codes lineups for Local Broadcast Listings for channel 1 where it now does give the BBC1 East Midlands channel - as per NG1 lineup
That is a separate issue - for the regional HD channels and the state is exactly as here
This is different and if HD BBC channels are now regional then I will need to refer that to gracenote
For now you have channel 1 as the correct regional channel but for 101 you have the BBC1 England HD channel
Update: Request passed to Gracenote to implement the changes outlined here Update on changes to BBC One HD on Freeview/Youview in England - Media Centre
Thanks.
I do find it strange though that I cannot select "001 BBC1 (BBC1EM) for channel “101 BBC ONE EMidHD” and I see the error message “There was a problem saving your DVR. Please try again” (as I posted above)
Shouldn’t I be able to select any listings I want for a given channel?
@e10kstarfire Channel 1 will be going soon anyways, so it’s best to stick with 101 just in case Gracenote doesn’t get it all updated before channel 1 is removed.
It might be because Channel 1 is SD and 101 is HD and marked as different program listings to channel 1.
Hi, trying to add a new channel (25.5, USA 33426 OTA) to my Live TV & DVR and can’t seem to match it. I’ve added it on my HDHomeRun and it works fine there. When I attempted to re-scan it found it on the Tuner Channels column, but I can’t seem to Match it under the Epic Channels one. I deleted it all together, re-did it but same thing. Not sure where to go from here. Here’s a screenshot for you. Any help would be appreciated.
The error to save changes arises when the same EPG channel is assigned to more than one Tuner channel number. So in this case, both tuner channels 1 and 101 were assigned to EPG channel 1. You can disable tuner channel 1 and just have tuner channel 101 mapped to EPG channel 1 and this should stop the error arising.
Thanks, I’ll try that. Would be nice for the error message to be more descriptive.
Plex Server 1.32.0.6973
Xfinity Frederick County
HDHomeRun Prime with cablecard
Many channels don’t match up for Xfinity Frederick County Maryland. 560 channels available and less than 100 match up. Some are duplicates, but many are not.
If they are mapped manually they will show up fine, but there are too many to map manually.
Rescanning, deleting and readding tuner has no effect.
These all mapped correctly previously.
Anyone? Would really like to map 25.5 MeTV. Sounding like there’s channel mapping issues going on right now?
Hi @sa2000, I PM’d you on this topic in case you didn’t see it, please let me know what other steps or information you need, or if the message didn’t make it somehow. Thanks!
Channel 5 (UK) has several programmes for next week showing as To Be Announced. The one I screen-grabbed is 7pm on Sunday.
I noticed today that BBC1 had become unmapped, possibly due to the changes regarding the regional HD channels, as the name appears to have changed to 001 BBC West Midlands HD (BBC1WMHD)
I remapped it like this
but this new channel appears to have no logo and is showing text instead
I’m not picking up the full listing for PBS America in the UK (Location 84).
It broadcasts on Freeview from 13:00, but for example today, 01/05, the first program shown starts at 14:40 and the last program shown finishes at midnight, after that there are no more listings at all.
Hope this it the right place to post this problem.
Also following the recent changes on Freeview some channels that are not HD are being tagged as HD. For example:
  • 001: BBC1 (and as @gadgetchannel mentioned us also being identified now as BBC1WMHD where as that is new regional name for channel 101 here in the West Midlands)
  • 020: Drama
  • 027: Yesterday
Incorrect HD tagging
Postcode: CV23
Las Vegas NV
Missing ION 34.1
I have referred the issue to gracenote for the following channels being incorrectly marked as HDTV
channel 20 DRAMAUK (Drama HD)
channel 27 YESTDAY (Yesterday HD)
channel 79 EARTHXEU (Earth X TV (Europe))
I have also notified Gracenote that the Regional BBC 1 HD channel was assigned to channel 1 instead of 101. I have only reported CV23 as one example - not sure if the issue applies to all regions
I tried a Las Vegas zip code (89101) and I can see the 34.x channels in the Local Broadcast Listings lineup
vcn callSign affiliate CallSign
34.1 KMCCDT ION Television
34.2 KMCCDT2 Bounce TV
34.3 KMCCDT3 Court TV
34.4 KMCCDT4 Scripps News
34.5 KMCCDT5 DEFY TV
34.6 KMCCDT6 Grit
34.7 KMCCDT7 Jewelry TV
34.8 KMCCDT8 HSN
Let me know if there is still a problem and please provide me the zip code and lineup name
Thank you for reporting this.
I will look into this next week
Same issue for B68
I am also noticing this via the Freesat EPG Guide as-well. For example, today at 1:45pm - 2:15pm.
I noticed a few BBC channels having the same message.
Same here, has been happening for a couple of weeks now to BBC1 and Channel 5
