Server Version#:latest Plex pass
Player Version#: latest - been same through months of updates beta and stable
I am unable to use the guide whatsoever on Android. It crashes to the home screen every time. After Plex removed plugins, the only reason I bought it for, I started to use the live TV predominantly. So of course that went out too . When it crashes it is still loaded but when I reopen it reloads the app.
This happened on both the beta and stable play store apps. Using stock Android 10 ,pixel 3, no root. Reloaded a bunch wiped cache and storage same result.
Not certain if your issue was the same as mine, but try the latest beta that was released on Tuesday (4/21). I had the problem and it related to a weird channel number description that Android couldn’t handle. In my case I had a channel number 33.1, that the EPG was loading as 33.1-1. The dash was causing crashes like you describe on all Android platforms. If I had unchecked that one channel no crashes.
The beta release yesterday resolved it after I sent them the logs of my crashing.
Hi @okmrdan Sorry If I missed this forum post and thank you for raising. @slim26 provided me with some logs that helped me fix the issue and I will extend that thanks out to you as well since you did try to report.
