Server Version#: Version 1.18.9.2571
Player Version#: Version 1.18.9.2571
Tuner Make/Model: tvhproxy (it doesn’t matter, same issue with all)
Guide/Lineup name:
Using XMLTV?: yes
Channel number/Name: all
Hi I have same problem. If I disable “new player” it start working… I use the last version on beta channel.
Live TV needs a bit more CPU than what you have. If you were lucky, you might get one stream going using PMP or Plex for Max/Windows which can direct play the mpeg2 stream. A browser is definitely out.
Turn off Verbose logging unless asked for.
Can you please provide some logs replicating this with the new player in Android 7.30, please?
Hi, here is the log file. I’m on Android TV (Nvidia Shield). 7.30.0.16390
plex_log.txt (1.1 MB)
My plex server (Linux) is on Version 1.18.9.2571
Server Version#: 1.18.9.2571
Player Version#: 7.30.0.16477
Nvidia Shield Version: 8.1.1(32.7.301.99)
HDHomerun Version: 20200225
Can not play live TV when new player is on. When channel is selectced screen shows background and spinner then eventually shows error. Error - An error occurred while attempting to play this video. Please try restarting both the Plex Media Server and this app.
I have tried this numerous times with no joy. Also I Have 2 Shields (2017/2019) and both experience the same issue.
Thanks!
Can you provide some logs, please?
Having a look at this, it’s to do with DNS rebinding with, which we have an internal fix for, and should be in v7.31 (in beta soon).
Thank you for the follow up.
No worries! Thanks for your patience!
Can you create a separate thread for that, please?
Yes of course!
Yipiiiieeee! 7.31 has fixed the Nvidia Shield Android TV Live tuner issue with the new player. Now to optimize the performance… Thank you Plex Team
Hi, I am having the same issue on nvidia shield. disabling “new player” solves the issue.
Summary :-
Windows Plex client works fine.
Chrome browser clients work fine
Android app does NOT work (same error as shield) - but there is no way to disable the new player that I can see.
nVidia shield client app does NOT work with new player, . version 7.31.0.168802
nVidia shield client app DOES work with old player, . version 7.31.0.168802
All on my local network, some wired, some wifi
HD Homerun quattro
Plex Media server (1.18.5.2309) on synology NAS DS918+
Do you have some logs you can share from the client?
Hi. I dont know how to do this. However, I did some more research on your forums and I found a solution that fixed everything for me on both shield and android phone…
disable “prevent dns rebind attacks” on my router.
