It has nothing to do with Linux TV. This is 100% a Plex issue.
When you use a modified xmltv that doesn’t report the end of a program, it no longer restarts. So it is unrelated to the contents of the stream or any drivers/codecs used to play the video or anything in the kernel. It’s simply a badly-functioning Plex feature that’s reacting wrongly to seeing the end of a program in the TV guide
I figured so much based on other people’s reports of this issue. Apparently, I finally got it to work as before by rolling back the server to the previous working version (1.19.4.2902) AND refreshing the Guide… twice. Thanks.
Server Version#: 1.20.1.3252-a78fef9a9
Player Version#: 1.20.0.1406-f47a81b7
Tuner Make/Model: HDHomerun HDHR5-2US
Guide/Lineup name:
Using XMLTV?: No
Channel number/Name:
You’ll also notice that compounded with this issue, managed users can only watch live tv for 4-5 mins before the feed just closes.
HI Long time user of PLexTV, I have the same problem, I currently use PLex mostly for live TV, every hour I cringe… that I need to manually start the next program.
Win Version 1.20.0.1406-f47a81b7
Server 1.20.1.3252
OK, I tried to look for the older version of the server 1.19.4.2902, could not find it, however try to update, said I was upto date, howerver on the PLex Site it is version 1.20.2.3402 of Oct 2nd. I have installed it. waiting for the next hour to see if it is fixed.
Same issue watching on web (safari), Apple TV, and a Fire tv. At the TV show switch point, it starts back at the time the show was turned on. Have caught myself watching the same NFL/NASCAR over after nodding off in my recliner and not seeing the restart.
Currently, my Octopus stops streaming completely after a broadcast has been canceled due to an error or bug. Before the stream jumped at the beginning of the playback, now it breaks off completely. I know the Octopus is not officially supported, but before updating a certain version (unfortunately I don’t know which one) it worked wonderfully.
