Live TV stuttering
Server Version#: 1.22.0.4163
Player Version#: 8.14.1.23548
Tuner Make/Model: HD HomerunConnect Quatro
Guide/Lineup name:
Using XMLTV?:
Channel number/Name:
I am having problems with Live TV, it can play absolutely fine for hours and all of a sudden it will just buffer and stutter continuously until you exit Live TV and go back in again, sometimes a reboot is in order!
Using Nvidia Shield Pro as the player and Synology DS214Play as the server. I have also tried disabling Live TV on the Synology and actually setting up the Plex server on the Shield instead but this has the same results.
I took a video of this happening here: 20210320_203755.mp4 - Google Drive
Recorded TV works absolutely fine, it seems to only be affecting Live TV
Anybody got any tips or things I can try? Its driving me mad!
Many thanks
Gary
This is being worked on. Install the 8.15 beta to fix it and then help us debug it!
Beta version of Android Plex? How do I install that on shield please?
Edit: have signed up now and am running 8.15 beta, let’s see how it goes
