Local Files for TV Shows Trailers and Deleted Scenes
Server Version#: latest
Player Version#: latest
I am trying to add deleted scenes to a TV Show. I have it set up as follows. They are not showing. Any suggestion? I also renamed with -deleted and still no luck?
Screenshot 2023-07-15 at 4.00.09 PM
Did you refresh metadata for the show after adding them, and are you using the Plex TV Series agent for the library?
Make sure you refresh metadata at the show level after adding the files. A media scan will not cause local files/extras to be shown.
start with the basics… forgot to refresh. duh!!
Thanks all!! they show under the main TV show now
Can I add them to a specific season and have them show with episode: example-
Season 1 (folder)
Show Name (year) - S01E01 - episode name-deleted.ext
I tried it but didn’t work?
Yes, you can add season- and episode-level extras as long as you follow the naming guidelines. The chart at the top of that article is important though, since it calls out that not all clients can display them (notably, the web/desktop app can’t show season- or episode-level extras).
