Hello,
my first topic post.
i am running a plex server on my computer and trying to access media files on my phone within same network. (at home)
server is version 4.159.0
i use iphone and plex app is up to date.
router is Asus Rt-AX82U
the problem i have is that some times plex app on my phone ask for remote pass, and if i turn off wifi on computer and turn it back on, the phone app works fine and not ask for remote pass.
please help fix this.
thank you
Jay
- servers should only use one network connection. If your server is on a laptop, and you are moving it frequently around, switching between WiFi and wired connections all the time, you will have to stop and restart the server after such a network change (and potentially perform a “Switch User” operation on clients as well, afterwards).
- servers should use a wired network connection. (it doesn’t matter if your client(s) are wireless or not)
Further things to check: Client says it won't play from "remote server", although the server is local
