Server Version#: 1.16.3.1433
Player Version#: 2.38.0.998
I am running Plex Media Player Embedded on an Intel NUC6i7KYK, which is working fine, except when I try to use it with my Logitech Harmony Elite remote, the commands are doubled (e.g. every time I press the right arrow button, it skips two to the right (you can see it quickly move to one, then a second).
A google search suggested turning down command repeats in the Harmony device settings for the NUC, which defaults to 3. I’ve turned this all the way down to 0, but this didn’t seem to make any difference at all.
Unfortunately that doesn’t work. The Microsoft PLEX device uses Bluetooth to control PMP running on Windows (or Mac) and so isn’t applicable to an embedded install.
