Hi, I have the full series of DBZ on my server and plex is struggling to order the episodes. For each episode in the first 100 named from 001 - 100 it lists two files, episode 001 also shows reads episode 101. Is there any naming trick or anything I can do to fix this?
I think this currently is a Bug in PMS failing Series with episodes over 100.
I saw it reported somewhere…
Will Plex Fix It???
Your guess is as good as mine…
LOL
I do have shows with 100+ episodes per season. however, I’ve named them sXXe01-sXXe99 and only then shifted to a 3-digit episode number (sXXe100-sXXeYYY).
Thanks for the swift replies. So to clarify can I name all of the episodes s01 or do I have to break them up into random different seasons before they hit the e100 mark? Will it not work having 3 digit frame padding from 001 to 099? Should I go from 1-99?
