Lost Access to PMS
I have been using Plex for about 10 months now and it has been working relatively well. I purchased the lifetime Plexpass as I plan to utilize Plex for many years to come. I woke up to an email the other night saying that a new sign in from a new location was detected. I verified that the password was one that has been in a previous data breach so I updated it and signed out of all devices. After signing back into Plex with the new credentials I haven’t been able to access my media. Using the Windows desktop app I would get either server is unreachable or the no soup for you message. I logged onto my Synology NAS and double checked share settings. I began looking through support forums trying to find a similar case. After spending about 3 hours digging I decided to unlink my PMS so that I could add it back. The setup utility for claiming your PMS isn’t coming up and at this point I don’t know what else to try.
I did update the NAS to 1.18.7.2434 as a part of the troubleshooting so it is now running the most current version. I saw in a previous topic that logs were requested so I have added them here.
Any help would be appreciated.
I would like you to do the following:
  1. Sign out of Plex/web (upper right corner)
  2. Restart DSM and let Plex come up normally with it
  3. After DSM finishes restart, give Plex about a minute to stabilize itself.
  4. Now open http://ip.addr.of.syno:32400/web
  5. You will be asked to log in.
I expect it will also tell you it found a server / server unclaimed.
Go ahead and reclaim it.
Please report your progress.
Hey Chuck,
Thanks for the reply. I have previously tired signing out and have restarted the DSM multiple times. Even so I followed your directions and the results are the same. When I log into my account I am greeted with “Your home screen is empty.” When I click on Your Media it wants me to download the exe for the PMS.
I also tried uninstalling the PMS from the DSM and then reinstalled the newest version with no change.
Any other ideas?
bump!
Sorry for the delay. (Eyeballs deep here).
If you’re using the version downloaded from Plex, uninstall it and download direct from Package Center. Install it and then let it have a minute or two to stabilize (1.18.x -> 1.6.6 downgrade takes a moment)
If still failure, Please make a ZIP of the “Logs” directory (under “Library”) in the Plex share. You will need navigate using File Station to get down in there to it but will see it.
