Server Version#: 1.18.2.2058
Player Version#:Unknown, Downloaded today on LG webOs if that helps
Hi.
I’m hoping there’s an easy answer to this as I’m VERY green when it comes to setting up Plex as usually, I’ve just had to install it and it all works fine.
Anyway, easy description is that I can copy any of my video torrents to a USB Flash Drive (720p, 1080p or 2160p versions) and it plays perfectly acceptably on my new TV. (LG 65SM8600) However, when I try to play the same file through Plex over my network (1Gbps) the picture quality is absolutely terrible, almost unwatchable. I didn’t have this problem on my old Samsung Full HD set.
Does anyone know if this is this a settings issue or is Plex not too good with LG TV’s ?
I have a 2018 LG and it works fine with almost all content.
In the Plex LG app settings you should have Quality set on Original, direct play and direct stream enabled. Depending on your LG the audio settings all codecs should be enabled if a recent model.
Thanks for the reply SE56. Those settings are all applied in the player on the TV. It’s a 2019 Nano-Cell so a recent model.
Unfortunately, being a Plex apprentice I don’t really know where to look. I’m guessing it’s a processing issue coz it works absolutely perfectly via the USB stick ?
Thanks again SE56. In the activity area, it shows both audio and video transcoded.
Not sure exactly what you mean by watching this remotely but the TV is on my home 1Gbps network as is the pc that I store the files on and run Plex.
Attached screenshot of my Transcode settings. I don’t appear to have the hardware acceleration option. PC is i7-3770 CPU, 16GB RAM, 128GB SSD C: Drive & 2 X 4TB WD Red HDD’s in RAID 1 (Mirror) for Storage if that helps.
